1999 lincoln navigator, rsx 3.5
mortarb2
Member - Posts: 6
Posted: June 14, 2007 at 10:34 AM / IP Logged
I have all the wires wired correctly and the thing will not start. Do I need a bypass of some sort here? Thank you
azaudio41
Member - Posts: 11
Posted: June 14, 2007 at 10:42 AM / IP Logged
yes you will need a bypass. that vehicle uses the PATS immobilizer, the bypass made by DEI is the 556UW
enice
Silver - Posts: 857
Posted: June 14, 2007 at 3:59 PM / IP Logged
Like azaudio41 mentioned in the previous post you can use the 556uw but you would lose a key.  If you'd like, you can use a KEY-OVERRIDE SL. Just connect 2 basic wires at the connector in the key cylinder and of course your ground, power, ign, and gwr and your done.
jim hunter
Silver - Posts: 351
Posted: June 14, 2007 at 5:16 PM / IP Logged
or you can use a d.e.i. 555f or 555p so you do not lose a key, just sometimes can be tricky to find a sweet spot t secure the pellet so that it works when all is assembled it is sometimes trial and error, or use a trilogix bypass
jim hunter
Silver - Posts: 351
Posted: June 14, 2007 at 5:19 PM / IP Logged
to test all your connections and programming, put your key in the ignition, do not turn it on just let it sit there and try to remote start it as it will read the key for the pellet, also forgot to mention in my previous post you must have 2 working keys to enter the p.a.t.s. programming to learn the bypass so if as most older cars do you only have 1 key youll have to get the dealer to make you a second key first then either put that key in a 556u or use the 2 keys to then program the 555f or 555p
enice
Silver - Posts: 857
Posted: June 14, 2007 at 5:55 PM / IP Logged
the KEY-OVERRIDE-SL distributed by crimestopper and or compustar needs ONLY 1 KEY to program. The link to the bypass is here... KEY-OVERRIDE-SL
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
