peugeot 206 xs 2003 petrol alarm wiring
tzibiboss
Posted: June 17, 2007 at 3:14 PM / IP Logged
hi!!
i have problem locating door switch, so i connected the alarm to the lamp. but the lamp is dimming and an annoying sound is produced by the relay. please help
sorry for my english:)
peterubers
Silver - Posts: 706
Posted: June 17, 2007 at 4:46 PM / IP Logged
Does your car have one of those black rubber covered door switches on the center pillar where the door comes to close and lock?  If so, behind this wire are usually two wires, one of which carries 12 volts, the other is chassis ground.  That can serve as your switch.
The search function is your friend.
tzibiboss
Posted: June 17, 2007 at 5:32 PM / IP Logged
no. unfortunately the switch is incorporated in the doorlock. and because my peugeot is multiplex the cables there do strange things( change polarity when i close the door and change again when i lock. etc.)
peterubers
Silver - Posts: 706
Posted: June 17, 2007 at 7:43 PM / IP Logged
are all interior lights "theater dimming?"  If not, sometimes there may be footwell lights or lights built into the door itself that illuminate the pavement that are on/off (i.e. do not dim).
tzibiboss
Posted: June 18, 2007 at 8:36 AM / IP Logged
no. my car has only one light. the central above me. (i don`t know how is called in englishpeugeot 206 xs 2003 petrol alarm wiring -- posted image.)
someone told me that there is a simple electronic circuit that makes the relay to ignore dimming and gives only a pulse.
this thing solves my problem.
thank you for your replypeugeot 206 xs 2003 petrol alarm wiring -- posted image.
