Trying to make the beep longer on Viper 800esp?
maximaonbags
Posted: February 14, 2003 at 11:42 AM / IP Logged
The only idea that I have had thrown at me is to wire up a "capacitor or 2" in the siren's wiring, but I really don't know how much that would actually do to make it work.
I am trying to make the actual "beep" longer when I arm and disarm the alarm... basically to have it go from "beep beep" to "beeeep beeeep" (on unlock of course).
This may be very simple, but I really have no idea where to even start?
Reasoning behind this is because I have a showme siren as my alarm siren and it needs a longer signal to have it make noise on short beeps.
Thank you in advance.
Jason Sadler
maximaonbags
Posted: February 16, 2003 at 10:30 AM / IP Logged
No ideas?
maximaonbags
Posted: February 18, 2003 at 10:05 PM / IP Logged
Still looking for some help..
RocketRanger
Member - Posts: 22
Posted: February 18, 2003 at 10:16 PM / IP Logged
Your cap idea could work.
I'm thinking a relay cap combo. Have the siren out of the alarm drive a relay instead of the siren itself. Place a cap in parallel with the coil side of the relay.
Finding the discharge time of a cap\coil combo is very easy.
T=RxC    You need C=T/R
T=Discharge Time to 63% of Supply (12V)
R=Load Resistance (Standard Bosch Relay is 80-100ohms)
C=Capacitor value in fareds
Example:
I want my relay coil active for approx .25seconds (T=.25)
I have a bosch 100ohm coil relay (R=100)
I need a capacitor size of 2500uF (.25/100=.002500)
(Remember electrolytics have polarity. No backwards!!!!)
This value would be a starting point. You'd have to experiment with cap values until you find an acceptible value. WHY? Relays latch up hard at 12V, but can hold to as little as 2V. Depends on size of relay.
I'd start with a value of around 470uF. You can also start with a large cap (2500uF maybe?) and put resistance in parallel with it to drop discharge time to what you need (Use 200 Ohm 1Watt resistors) Don't exceed the current capacity of your alarm siren output.
Recommend starting with a 470uF. Add another in parallel if not enough time. Test unhooked from alarm siren out. Manually simulate the 12V siren output by taping a wire on the cap\coil combo positive connection. Easier to figure acceptible time..
Hope this helps....
Rocket
You must experiment.
EVSolutions
Member - Posts: 8
Posted: February 18, 2003 at 11:26 PM / IP Logged
Rocket,
Is it possible to use the relay as a delay on timer say, 6 to 8 seconds with caps?
Sean
RocketRanger
Member - Posts: 22
Posted: February 19, 2003 at 1:07 PM / IP Logged
Would take more then just a relay\resistor\caps.
Other options:
555 Timer IC
-MANY books on this. Radio Shack has a $3 book
-Cap\Resistor\Transistor\Relay combo would work
Recommend 555 timer reading.
Interested in any ideas from others who know a simpler way to do the above mentioned timed-on relay. I know there are commercial timer relays, but they are way to expensive.
Rocket
