cooling fans
tdsteele
Silver - Posts: 393
Posted: July 01, 2007 at 7:15 PM / IP Logged
Is it ok to hook these two cooling fans up to the amp remote turn on wire to power them?
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=259-125
Installer_mss
Copper - Posts: 221
Posted: July 01, 2007 at 9:57 PM / IP Logged
use a relay to power the fans and the amps and any other accessory needed to be turned on by the head unit.
the turn on lead is only at most 1 amp (.5 in most cases) and can only power 2 pieces of equipment max, beyond that you need a relay.
85 - ground
86 - remote turn on lead from headunit
30 - out to everything to be powered up by turn-in lead (amps, crossovers, fans, etc.)
87 - constant power
87a - not used
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
