clarion pro audio apa2104 fried?
jmelton86
Gold - Posts: 1,228
Posted: July 04, 2007 at 6:54 PM / IP Logged
ClarionProAudioAPA2104. I was running it 2ohm stereo for about 6months. Anyway, one day it stopped working, correctly. It'll play until over 1/3 volume, then it cuts out and distorts like it's not getting 12v. I tried using the volume knob on the stereo(gain down) -nothing. Tried turning the gain all the way up(volume down) -Still, cuts out and distorts. This happend at the beginning of May, so I figured the hot weather and 2ohm stereo have done their part on it. Is it gone, even though it plays at low volumes?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
DYohn
Platinum - Posts: 10,741
Posted: July 04, 2007 at 6:56 PM / IP Logged
Yes, sounds like the amplifier needs repair.  Note that the gain control is NOT a volume knob and should not be used as such.
Platinum - Posts: 13,725
Posted: July 04, 2007 at 7:44 PM / IP Logged
    Before you write the amp off it would be a good idea to do a little troubleshooting.  Do you own or have access to a volt meter?   If you do, with the amp playing above the 1/3 volume level you need to check voltage across the power and ground terminal of the amp.  If it is reading 12 volts or above, then you may have a bad amp.  If it is lower than 12 volts then a little more troubleshooting is in order.  Let us know what you find out.
jmelton86
Gold - Posts: 1,228
Posted: July 04, 2007 at 7:47 PM / IP Logged
Thanks. Well I turned the gain up with the volume almost all the way down, just to see if anything different happend.
What kind of repair does it sound like? Am I better off getting something new(er) for the price i'd pay to repair it?
Big3 in 1/0G
1/0G to GTO14001
jmelton86
Gold - Posts: 1,228
Posted: July 04, 2007 at 7:49 PM / IP Logged
It's getting 12 plus volts. Wiring is better than what it needed to begin with.
Big3 in 1/0G
1/0G to GTO14001
furflier
Copper - Posts: 236
Posted: July 04, 2007 at 8:21 PM / IP Logged
 Have you checked to see if the ohm load has changed?
jmelton86
Gold - Posts: 1,228
Posted: July 04, 2007 at 8:54 PM / IP Logged
The problem occured with the original 2ohm stereo load. When I was messing with it I had it bumped up to 4ohms stereo and it still persists, is this what you mean?
Big3 in 1/0G
1/0G to GTO14001
furflier
Copper - Posts: 236
Posted: July 05, 2007 at 7:29 AM / IP Logged
Yes that is it. Looks like it is repair time.
Wednesday, January 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
