do i have to upgrade the big 3 with.
jerad73
Posted: July 09, 2007 at 4:22 PM / IP Logged
Right now i have quality wiring running throughout my car. Its not actual car stereo wire, but what it is is HIGHER grade 4 guage wire that is designed to withstand higher temperatures at a longer time than car wire, thats why it also cost much more money
Well im upgrading from a basic 500 watt rms amp that goes to 3 subs at a 2.67 ohm load
to a..
1200 watt rms amp to 3 subs at a 2.67 ohm level.
Do i Have to upgrade to a bigger alternator, battery, and wiring?
Can i go without any of this because i already have quality wiring?
What is the bare minimum i can do?
PLEASE HELP!!! do i have to upgrade the big 3 with. -- posted image.
( The vehicle is a 2005 Ford Escape XLS 2.3L 4cyl.)
Thanks Again.
haemphyst
Platinum - Posts: 5,059
Posted: July 10, 2007 at 12:27 AM / IP Logged
The wire doesn't matter... It's the load being placed on your alternator, PERIOD.
An additional 1200 watt amplifier (if digital, this will be the best case scenario, if class A/B, the numbers will be HIGHER) will be another 92A worth of load that the alternator has to supply current for, and I expect that that alternator ISNT more than about 65A as it is!
Upgrade your alternator... which necessarily means an upgrade to the Big 3 as well.
sarcomax
Copper - Posts: 276
Posted: July 10, 2007 at 11:32 AM / IP Logged
Just curious as to what wire you have running where that is better than car wire for a car application. Did you capture a downed alien spacecraft and steal it's technology? Where can I get some?
haemphyst
Posted: July 10, 2007 at 4:34 PM / IP Logged
Funny, but the stuff DOES exist... A good quality, flexible welding cable is a place to start looking for such a specified cable. Teflon insulation, rope lays, mega-multi strands... they all exist. As far as I am concerned, in the car all you are REALLY worried about should be temperature and chemical resistance, first and foremost. Multiple strands are a good place to look next, as the car (being a place frought with vibration) will be quite a bit happier with a nice flexy cable... it'll just lay in place nicer, too. I would finally look for abrasion resistance, although this won't be QUITE as important a spec, certainly. A properly installed power cable should already be routed where there won't be a potential for abrasion.
