using a relay to complete a circuit
vtail
Posted: July 12, 2007 at 8:38 PM / IP Logged
First of all...please forgive my ignorance.  I've been reading through lots of posts trying to find an answer to my question without success.  I would like to know what kind of relay to use to complete a simple circuit.  I'll try to explain...I would like to power the relay with a 12volt switched power and ground....when the 12v is applied to the relay, I would like two terminals without any voltage to them to complete a circuit.  Hope I'm describing this well enough to get an answer.  Thanks in advance!
vtail
hotwaterwizard
Silver - Posts: 1,350
Posted: July 12, 2007 at 10:04 PM / IP Logged
Easy one. Right application. Where is the circuit?
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
duct tape
Copper - Posts: 125
Posted: July 12, 2007 at 11:15 PM / IP Logged
using a SPST or SPDT relay:
pin 85 goes to your output of the 12 volt switch
pin 86 goes to ground
pin 30 goes to one side of your circuit
pin 87 goes to the other side of your circuit.
when 12 volts is triggered from your switch, it will close contacts 30 and 87, thus completing your circuit.
hotwaterwizard
Posted: July 13, 2007 at 12:12 AM / IP Logged
using a relay to complete a circuit -- posted image.
Stockton California
vtail
Posted: July 13, 2007 at 7:24 AM / IP Logged
Wow...I knew this would be easy for all of you!  Thank you very much for the quick responses!!!
vtail
