amp killing car battery
whiterob
Copper - Posts: 351
Posted: July 23, 2007 at 1:23 AM / IP Logged
I had a sub amp that i used to run 2 subs off of.  later my battery kept dying so i thought it was bad.  i took out my fuse to my amp and it didn't die anymore.  so somehow my amp was draining my battery.  i looked at the amp and it wasn't on or running or anything so i couldn't figure out how the power was draining.  anyone have an idea why my amp would drain my battery.
DYohn
Platinum - Posts: 10,741
Posted: July 23, 2007 at 9:44 AM / IP Logged
Assuming you mean the battery is going dead while the car is parked, there are several possibilities.  1) remote turn on is powered. 2) amplifier is bad. 3) wiring is bad. 4) battery is bad. 5) some other wiring or equipment issue not really related to the amp.
whiterob
Copper - Posts: 351
Posted: July 23, 2007 at 2:59 PM / IP Logged
it is not the battery because it was replaced and it still died.  i think i narrowed it down to either the amp or the remote turn on.
aznboi3644
Gold - Posts: 2,600
Posted: July 23, 2007 at 5:38 PM / IP Logged
what amp is it?? How big is your alternator?? What gauge wiring do you have??
mando2155
Copper - Posts: 74
Posted: July 23, 2007 at 9:13 PM / IP Logged
Have you had your alternator output tested?  I think theres some auto stores that will check it for free.
sarcomax
Copper - Posts: 276
Posted: July 24, 2007 at 12:04 PM / IP Logged
+1 on the alternator test. How many miles are on your car, and is it the original alternator? How much is your amp drawing? I would guess that since you were removing the amp from the charging system, that the alternator was able to charge the battery, without the unknown thumpin 2 subs running off the unknown amp drawing an extra unknown amount of juice.
DYohn
Posted: July 24, 2007 at 5:14 PM / IP Logged
A bad alternator will not cause the battery to be drained while the vehicle is off.  Yes, if the battery is being drained while the system is operating and the engine is running, the alt is a likely suspect.  But I think the original poster is talking about his battery being drained while the vehicle is parked and the system is off, like over night?
whiterob
Copper - Posts: 351
Posted: July 25, 2007 at 2:42 AM / IP Logged
yeah i haven't been able to look at it yet but i am thinking that the amp is bad.  it only dies when the car is off and i don't think it is the alternator.
mjwood0
Member - Posts: 38
Posted: July 25, 2007 at 5:39 AM / IP Logged
If the car is off and the system is off when the battery drains, it has nothing to do with the alternator.
There are only so many things drawing power from your battery when the car is off. Disconnect the amp and verify that the battery doesn't drain. Once you've established that, hook it back up and probe the remote turn-on lead. Verify it works as expected. If so, you may have a wiring problem to the amp. You could always just connect the amp under the hood temporarily to verify that it's the amp and not the wiring.
sarcomax
Copper - Posts: 276
Posted: July 25, 2007 at 12:21 PM / IP Logged
I was only suggesting alternator test because I have had the joy of replacing one in my car because my weak little system was drawing just enough that the battery was not getting charged. I would park the car after work, and 10 hours later the battery would be dead. After a week of 6am jump starts, I tested the alternator and it was a whopping 50 amps. I only drove the car about 10 minutes each way, and every day my battery was dead. With such a short commute, I was not driving long enough for the car to just die on me, but long enough that I was pulling so much from the battery that I could not start the car. I am just suggesting that he does all of the free stuff before he goes and drops money to replace something that was not the root cause. If the alternator is fine, then great, I am wrong and admit defeat (I was married once, I am used to being wrong...)
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
