twist or tape harnesses
enice
Silver - Posts: 857
Posted: August 10, 2007 at 6:33 PM / IP Logged
Thats where charging a reasonable price comes in.  Im pretty sure that having a stealth type of install is what makes a professional.  I totally understand where supply comes in but then again a customer that knows your installs are "stealth",  wouldn't mind the extra charge for supplies.  Then again a good sales rep would sell the cleanliness of an install and show that it just doesnt matter that it works but also the cleaness of it.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 11, 2007 at 12:59 AM / IP Logged
True "stealth" is hard to do.... I don't care how good you are, and everyone knows this. enice hit it, if your gonna make the alarm and remote start "disappear" under the dash, you DO need to get a few more dollars. It's the old saying......time is money!
kassdog
Copper - Posts: 257
Posted: August 11, 2007 at 1:57 AM / IP Logged
Don't you guys charge customers shop fees. From what I've seen in 4 years of installing around my area every shop usually charges $4-$5 on every car for "shop fee". And this fee can mean a lot of things but I've always assumed it means materials. I know that on most cars you aren't installing $4 dollars worth of materials.
swerks
Copper - Posts: 224
Posted: August 11, 2007 at 8:13 AM / IP Logged
most shops charge for supplies i dont but i charge enough to cover them
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
Posted: August 11, 2007 at 10:54 AM / IP Logged
Twisting is silly. Manufacturers only do it on speaker and can wire to cut interferance! Nuff said. What does PITA mean its a new one on me?
KPierson
Platinum - Posts: 3,527
Posted: August 11, 2007 at 11:18 AM / IP Logged
I disagree Howie, if I was going to choose one or the other, I would definately go with twisting over taping, simply for the fact that taping takes a minute or two, and twisting takes 10 seconds (and requires no tape, so no added costs).
Having the wires  twisted makes running them easier, and leaves a better looking install, as all the added wires will be grouped.
I've never owned my own shop nor had to worry about added costs, but I always did the best install I could for the customer.  This is one advantage to working for a 'big box' store that pays by the hours, and has basically unlimited resources.
The bottom line, in my book, is that no matter how much the customer paid, they paid for a PROFESSIONAL installation.  Professionals don't cut corners, especially just to save a few pennies per installation.  If a shop's labor rate isn't enough to cover a professional installation then they  need to adjust their rates/fees.
Kevin Pierson
frans-c
Copper - Posts: 77
Posted: August 11, 2007 at 11:22 AM / IP Logged
Uhm, please enlighten me...what's twisting?
F R A N S
1985 Mercedes-Benz 230E
320 000 km / 199 000 miles
Full MB Service History
xtremej
Gold - Posts: 1,440
Posted: August 11, 2007 at 11:29 AM / IP Logged
Twisting the wires together  with a drill, so they are pretty.
Posted: August 11, 2007 at 11:30 AM / IP Logged
KP is right but we have to "stealth" and conceal everything in UK, ONLY soldered joints except grounds when we often go back to bare metal and water resist sprays, mastic sealent over grommetts etc, convoluted tubing under hood more water resist on hood switches and rear of DEI Sirens, IP65 connectors when possible etc! Alarm CPU gets metal casing and MUST BE screwed or cable tied in place!
enice
Silver - Posts: 857
Posted: August 11, 2007 at 10:11 PM / IP Logged
The way I do it is twist and tape to make the stealth look.  It does take time but at the end if done right you have a very very clean install.
