tach bouncing, 06 f150
warbat66
Member - Posts: 11
Posted: August 01, 2007 at 1:28 PM / IP Logged
I am having problems with my 06 f150.  I installed two amps a 300 watt pioneer and a 800 watt rockford.  The rockford is powering a alpine type r 10 and the pioneer is powering my door speakers.  The problem i am having is that my tach is bouning up and down when i come to stop light or stop sign.  Im assuming that i am putting too much of a drain on the alternator, but my lights are not dimming.  Will a capaciter help? should i take out the pioneer amp?  any help would be great.  Thanks
xtremej
Gold - Posts: 1,440
Posted: August 01, 2007 at 1:37 PM / IP Logged
Need more info. Is the actual engine reving up or is just the tach needle moving? Specs power cable size, ground size, and model numbers  of the amps you have? Factory head unit or aftermarket?
audiomaninc
Copper - Posts: 108
Posted: August 01, 2007 at 1:48 PM / IP Logged
Sounds like it could be a bad battery.  Take the truck to your local Advance Auto, or Auto Zone, or whatever you have in your area and have them do a load test on the battery and the alternator.  Make sure your stereo is on and thumping when they do this.  We had this exact problem about a month ago with a Grand Cherokee, turns out the battery was weak so we ended up selling him a new one and voila, problem solved!  Good luck!
2003 Dodge Neon R/T
Alpine CDA9813, RF T2000.1bd, RF T162S, RFT142C, RF T600.4, RF T215D4
140.7 @ 28Hz
warbat66
Member - Posts: 11
Posted: August 01, 2007 at 2:46 PM / IP Logged
no the engine is not reving its just the tach.  all the cables are #4.  the head unit is a pioneer 7700mp.  Not sure about the model numbers for the amps.  The rockford is a few years old.  the pioneer is their bottom end 300 watt amp.
Thanks audiomaniac ill give that a try.
any other ideas?
xtremej
Gold - Posts: 1,440
Posted: August 01, 2007 at 2:54 PM / IP Logged
double check connections also, was the ehad unit installed at the same time the problem occured.
warbat66
Member - Posts: 11
Posted: August 01, 2007 at 5:06 PM / IP Logged
no the head unit has been in since i first got the truck about 10 months ago.  i did not have the problem with the pioneer amp and a kicker comp 10.  it all started when i took out the kicker sub and added the rockford amp and the type-r 10.     Will taking out the pioneer amp help?  a friend who is a professional installer is totally stumped.  The truck has a 130 amp alternator.  It is definately the system though because when i turn everything off the tach stops moving.
Platinum - Posts: 13,726
Posted: August 01, 2007 at 9:18 PM / IP Logged
If everything was fine till the Rockford amp, why would you think taking the Pioneer amp would fix the problem? If you take the fuse out of the power wire for the Rockford, does it still do it? Does the tach bounce with the beat of the music or is it just a random bounce?
warbat66
Member - Posts: 11
Posted: August 01, 2007 at 9:52 PM / IP Logged
its just a random bounce, i was thinking by taking out the pioneer amp i would lessen the load on the alternator,  an without the rockford the tach does not bounce.
01trublugt
Copper - Posts: 112
Posted: August 02, 2007 at 8:38 AM / IP Logged
How much of a bounce are we talking about here? Does it go from say at idle 800 up to 1000 or from like an idle of 800 up to 1500??
warbat66
Member - Posts: 11
Posted: August 02, 2007 at 9:14 AM / IP Logged
it drops to around 700 up to 1300 with out the stereo it has a constant idle of around 1000 or 1100
