wiring sub, 6x9's, 5.25's, amp
snakestance
Posted: August 02, 2007 at 12:15 PM / IP Logged
I need help in wiring what I have. Basically I have 1 10" sub, 2 6x9's, and 2 5.25" one 4 channel amd that is 2 ohm stable. Here it goes. DB Drvie Speed Series Speakers I hope someone can help me. Thanks in advance for all the great info on this awsome sight!!! This is going in my 1963 Ford Falcon.
wiring sub, 6x9's, 5.25's, amp -- posted image.
icbm-774
4 CHANNEL BRIDGEABLE POWER AMPLIFIER
MAX OUTPUT POWER : 250Wx4CH @ 2 OHM
POWER OUTPUT :
100Wx4CH @ 2 OHM
80Wx4CH @ 4 OHM
200Wx2CH BRIDGED
24dB/OCT. CROSSOVER SLOPE
VARIABLE SUBSONIC FILTER (10Hz-100Hz)
VARIABLE LOW PASS FILTER (30Hz-500Hz)
VARIABLE HIGH PASS FILTER (50Hz-1KHz)
VARIABLE 18dB BASS BOOST
HIGH & LOW LEVEL INPUT THROUGH RCA
DOUBLE SIDED PCB
DUAL PROTECTION (THERMAL & SHORT CIRCUIT)
RCA LINE OUT (PREAMP)
POWER & DIAGNOSTIC LED INDICATOR
2 OHM STABLE STEREO
SOFT DELAYED POWER ON
TRI-MODE CAPABILITY
0.05% THD
SP90.2
6 x 9" three-way speaker
300 watts
100 watts
45Hz - 20kHz
92dB
SP50.2
5.25" coaxial speaker
150 watts
55 watts
55Hz - 20kHz
89dB
SPW10.2D
10" dual 4 ohm voice coil
600 watts
300 watts
85dB
50 oz.
DYohn
Platinum - Posts: 10,741
Posted: August 02, 2007 at 2:02 PM / IP Logged
You want to operate your sub and four speakers from that single 4-channel amp?  OK.  First let me suggest you should purchase a separate 2-ohm stable mono subwoofer amp.  But, anticipating that you don't want to or can't do that:
You will be forced to give up front/rear fade.  Connect both "left" speakers to channel 1, both "right" speakers to channel 2.  Drive channels 1 and 2 from the "front" RCA output from your head unit.  Your sub is DVC 4-ohms, so you will have to either connect one voice coil to each of channels 3 and 4, or wire the sub in series (8-ohm load) and connect to the bridged output of channels 3 and 4.  Either will give you the same power utilization to the sub.  Drive channels 3 and 4 from the "subwoofer" output from your head unit and make sure that output is turned on.
Activate the HP filter for channels 1 and 2 and the LP filter for channels 3 and 4.  Set them both to the same frequency, about 80-100Hz.  Set you gains properly.
snakestance
Posted: August 02, 2007 at 2:24 PM / IP Logged
My head unit is an old but nice alpine in dash 3 disc changer. It has the rca's for front, rear, and sub. So I wire the left front and left rear to channel 1 (front rca) I then wire the right front and rear to channel 2 (rear rca). I wire the sub bridged to channel 3 and 4 (sub rca) Can I wire the sub in parallel instead of in series? Also, what is tri mode capability? Thank you for your help!!
DYohn
Posted: August 02, 2007 at 3:19 PM / IP Logged
No, I am suggesting you use only the front RCA outputs to drive channels 1 and 2 and do not use the rear RCA outputs at all.  Then use the subwoofer output to drive channels 3 and 4.  Tri-mode means you could potentially connect the sub across channels 3 and 4 and use one set of speakers on channels 3 and 4 in stereo.  But this will require two things: first that you drive channels 3 and 4 from the rear RCA output and not from the sub output (which means you will need to make sure the subwoofer crossover in the HU is off and that a full-range signal is going to the rear output) and second you will need to buy or build a passive crossover to use with the sub and the rear speakers.  If you decide you want to try this, I highly recommend you get some assistance from a local install shop (and expect them to give you crap about that amplifier being a flea-market brand.)
snakestance
Posted: August 02, 2007 at 3:27 PM / IP Logged
Got it. Would it be easier and better to just get a smaller amp to run the 5.25 in the doors, and then run the 6x9's and the sub off of the 4 channel? Thanks for your help. If I were to call for help and they gave me crap, I would just tell them politely that I was asking for some advice. If they would give me the advice, then great, if made fun of my amp, I would just say soory I wasted my time and yours. Thanks for all of your help. My birthday is coming up so, guess what I will be asking for??? Thanks again for your help.
DYohn
Posted: August 02, 2007 at 3:45 PM / IP Logged
I think you'd be better off if you do buy another amp to get a subwoofer amp and use this one as a 4-channel amp for the four main speakers.
snakestance
Posted: August 02, 2007 at 3:48 PM / IP Logged
Good thinking. Had not thought about that. Too wrapped trying to make it work with one amp!!! Based on the info of the sub, what would you recomend? I have the sub in a sealed box. I like bass, but not boomy base. More of solid thump!
DYohn
Posted: August 02, 2007 at 4:22 PM / IP Logged
Look for a mono amp rated at about 300 watts into 2-ohms.
snakestance
Posted: August 02, 2007 at 4:23 PM / IP Logged
OK
Thanks again for your help and advice. I really appreciate it. I have some ideas to go on now.
DYohn
Posted: August 02, 2007 at 4:32 PM / IP Logged
No prob, that's why we're here.  wiring sub, 6x9's, 5.25's, amp -- posted image.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
