kenwood cd/mp3 player
umarsher
Posted: August 03, 2007 at 5:37 PM / IP Logged
hi
i installed a kenwood car cd/mp3 player
it works fine but , when i start my car i can hear my muffler threw my speakers , and when the volume is at zero you can styll hear the subs rattling loudly .
can some one help let me know.
u .s.h.e.r
ceasar326
Copper - Posts: 239
Posted: August 03, 2007 at 6:25 PM / IP Logged
Do you have amps hooked up to your speakers or are they hooked up to the stereo directly? On what kind of car?
umarsher
Posted: August 03, 2007 at 6:37 PM / IP Logged
thanks for ur reply 1st of all
ok i have one amp.hooked up to the to 10'' subs and then the rca from the amp to the deck , and the speakers are hooked up to the deck. i have like 6 speakers in total in my car , its a 1992 honda accord ex. i had a cd player before kenwood also never had a problem , but i installed my new one in and i can hear my self driving and i can hear my exaust threw my speakers and subs.???? please help me
thank you
umar sher
u .s.h.e.r
Platinum - Posts: 13,726
Posted: August 03, 2007 at 8:44 PM / IP Logged
You need to first turn the CAPS LOCK off on your keyboard.  Then take a foot of 18 guage wire strip both ends, ground one end to wherever you grounded your radio. With your car running, engine noise a blaring, touch the other end of the wire to the shiny silver or gold part of your RCA cable that goes to your amp. This will make a Pop noise then the engine noise will go away. If this works let us know and we can let you know how to fix it.
umarsher
Posted: August 03, 2007 at 9:29 PM / IP Logged
sorry man at work , we need caps lock on always .
anyways so while the system runing touch the ground wire to one of the rca cables , only one right and leave the other on right like they have a l and r so touch one of them only right.and then just move it once it goes bang remove the ground from rca cable .????????? need more deatils bro , but ill try my best
thanks for your time
u sher
u .s.h.e.r
Posted: August 03, 2007 at 10:04 PM / IP Logged
Either patch cord will work, left or right. It will not go bang, it will just make a slight pop.  After it makes the pop, if you remove it the noise will come back. We are just doing this to make sure this is the problem.  The shield of your patch cord is the outer shiny part that you can see when the cable is connected to the radio. If this works, you have a problem with your radio. A temporary fix for this would be to solder the wire to the patch cord.
theterminator
Copper - Posts: 96
Posted: August 04, 2007 at 12:58 AM / IP Logged
You might want to check the location of your RCA and power wire. If they are too close to eachother that could also cause noise. Or it could possibly be a bad ground.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
