2007 silverado, starter kill
carlosa
Posted: August 06, 2007 at 9:54 AM / IP Logged
Hello can any on help me I am tiring to install a regular alarm system on my new Silverado 07 new style and I was trying to find a starter kill wire under the steering column but its to complicated I was reading that their is one on engine compartment driver side yellow/black (+) at the ECM I found one that is going to the fuse box and another to the small computer in front of the fender I just want to make shore before I cut any wires does any one have any drawings or I picture so I can relate I don’t know the number of the connectors
xtremej
Gold - Posts: 1,440
Posted: August 06, 2007 at 4:31 PM / IP Logged
Always verify with meter and you should be fine.
evileagletalon
Copper - Posts: 65
Posted: August 09, 2007 at 1:04 PM / IP Logged
Is a starter kill even needed on that truck? Doesn't the PATS kill the fuel pump and ignition once you take the key out of the tumbler?
jim hunter
Silver - Posts: 351
Posted: August 09, 2007 at 10:08 PM / IP Logged
truck has pkIII + which is pretty safe against theft, but can never be to sure anymore, to do starter kill in this truck you must go out under the hood and catch the yellow/blk wire ( if i remember correctly, test to be sure)at the ecm on the drivers side fender,
swerks
Copper - Posts: 224
Posted: August 09, 2007 at 11:53 PM / IP Logged
triogix makes a starter kill module for the new gms model sim-gm     bypasskits.com
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
