alpine mrp m650 on 8 awg?
somboy24
Member - Posts: 12
Posted: August 09, 2007 at 11:10 AM / IP Logged
so i'm getting rid of the old and inwith the new.... but not yet. i have the main system picked out it consists of a MPE-F450 to power the SPR-57LS in the front and SPR-57C in the rear. also i will have a MPR-M650 powering a 12" type r at 2 ohms. so the question is...... i h ave a nice 4AWG amp kit already going to the trunk and my heart is set on keeping that and getting a distrabution block the split the 4 AWG into two 8 AWG the power each amp. i know the MPE-f450 will work with the smallerr cable but will the bigger MPR-M650?  If this just isint going to work how would the smaller MPR-450 compare?
   also how does the system look so far honestly before i order it all lol
xtremej
Gold - Posts: 1,440
Posted: August 09, 2007 at 11:22 AM / IP Logged
Should be fine, remember after distribution the 8 gaugs run will probably be only a few feet at the most. Make sure to either get a fused distribution block or fuse each 8 gauge lead off of the distro block.
somboy24
Member - Posts: 12
Posted: August 09, 2007 at 11:54 AM / IP Logged
Thanks for the quick response! ok so now for the fuses the 4 AWG has a inline fuse on it already would it be safer to put the fuses on the 8 AWG going to the amps, this way i would have two and i  could get the right size fuse for each amp or should the fuse i have already be fine. also how does the setup look so far?
help?
xtremej
Gold - Posts: 1,440
Posted: August 09, 2007 at 2:44 PM / IP Logged
remember the in line fuse are there to protect the power wire not the amps. Keep the inline fuse at the head end of the 4 ga by the battery cable. when you buy a distribution block just get one that is fused. The reason is simple, the 4 gauge wire can handle a lot more current than the 8 gauge so fuse accordingly I would think and 80a for the 4 ga-- maybe 40a for the 8 ga.
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
