morel vs dynaudio 360
lincoln2002lse
Member - Posts: 31
Posted: August 12, 2007 at 8:49 PM / IP Logged
   I have been running the Focals 165v2's in the front doors of my 2002 Lincoln LSE and to tell you the truth for a "mid" they are fine but,,, there sure is nothing in the lower freqs that are making me happy, especially if I try to put a little JL-450/4 juice to them. I have been beating my head against the wall trying to get the lows to mesh with the front and back and I think the limits of the Focals have me beat. I put three layers of dynamatt all over the doors, (inside,, and inside of the outer skin), as suggested by many others and on top of that added some closed cell foam. Yes it helped a little but mostly made the Lincoln heavier,, lol and yes quieter.
   I went by the local shop today to demo the small Focal ks13/13ks (something along that line) 5.25 "sub",, lol,, but there is a new version of it about to hit the store so I am going to hold off till I get some word back from the owner of the place as to his thoughts and to also give them a listen. (I won't let them work on my car anymore but they do have nice equipment there,, including Kef, Theil, Klipsch, etc...) But not Dynaudio of Morel.
   Now jamming two speakers in the front doors is going to be a challenge in itself and am very seriously thinking of going with Dynaudio 360's, I think with some very careful cutting and bracketing I will be able to put the 3" mids of the 360's in the OEM (2") center positions of the LSE, sound reflection is of course a big concern, and the 8" will fit the doors with only a very little mod. ,,,, or,,,,, should I take a look at a set of comparable Morels?
1. Seriously cut the car to fit another Focal speaker in the door, spending about $200.00? (Lincoln filled the kicks with electronics's)
2. Cut the car to fit a set of Dyn 360's $800.00?
3. Cut the car to set up for Morels?  $$$
$ isn't reallty the issue, it's the bruising on the forehead that has me concerned at this point
   Can anyone make sence of the article above and if you have any input on these issues please let me know
smgreen20
Member - Posts: 36
Posted: August 12, 2007 at 10:09 PM / IP Logged
I'm trying to figure out if you're looking on ebay for the Dyn 360s cause that's the only way to get them for $800. You'll need to be carefull of the fake Dyns that are out there. I just got rid of Dynaudios system 240 MKII to buy a set of Phoenix Gold Ti6 Elite comps made by Morel after their Elate line. $299.99 SHIPPED on woffersetc.com Being that Morel is/was a sister company of Dyn you can't go wrong w/either. I prefer Morel by a hair. I would spend the xtra $$ and go w/Morel as I despise doing major (anything involving cutting the metal) work to a vehicle and try to steer clear of it as much as possable.
jvillefinest
Copper - Posts: 255
Posted: August 13, 2007 at 12:35 PM / IP Logged
so why not upgrade to another level of focal if you like them??
2007 Acura TSX
SQ setup in the works
lincoln2002lse
Member - Posts: 31
Posted: August 13, 2007 at 7:16 PM / IP Logged
To answer jvillefinest, I would have to say the numbers alone on the Focal speakers say a lot, and of course it is the freq's I refer too.
I had the K2p and found them lacking in the same area, I sold them and stepped down a little for the time being, got more then what I paid for them b/c the guy that heard them wanted them straight out, and right now, still the lows in the k2's were not what I was expecting. A bigger driver--- more mass, is where I feel I need to move to and the (8"dyn or 9" Morel) should do the trick,,,
I do worry though of loosing the clarity of the true mid section when I do this.
Eclipse / JL / Focal- - - Dynaudio//Morel
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
