How Do I Wire In An Extra 12v Cigg Light
Suppy7
Member - Posts: 8
Posted: February 17, 2003 at 11:40 AM / IP Logged
how do I wire an extra 12v cigg lighter in my car. My plan is to wire it for the backseat. What exactly do I need to wire to get it to work proerly??? is it just a matter of a Red wire and a black wire??? And where would be the best place to wire it to??
copcarguy
Copper - Posts: 122
Posted: February 17, 2003 at 2:07 PM / IP Logged
Query- What are you planning on running off of this lighter or is it just for convenience? Need to know before going further.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
Suppy7
Member - Posts: 8
Posted: February 17, 2003 at 5:12 PM / IP Logged
just accessories - no actual cigg lighting - neon lights no heavy duty stuff
Fred Berge
Member - Posts: 10
Posted: February 24, 2003 at 12:16 AM / IP Logged
Run a wire from your fuse block to where you want your lighter. You can hook it up either constant or when you turn your key on. Connect that wire to the center post
on the cig. lighter, run a wire from the side connection
of the lighter to ground. Make sure you fuse the wire coming off the fuse block i would use a 10 amp fuse.
crucial
copcarguy
Copper - Posts: 122
Posted: February 26, 2003 at 8:46 PM / IP Logged
Sorry for the disappearing act! Be sure not to install the lighter facing up as dimes, pennies and foil gum wrappers have a way of falling in and shorting out the circuit. you could also install a spst switch to turn it on/off manually for an extra little feature.(just a thought).
R Jackson
Owner/Installer
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
