rs, door unlock pulsing twice
scottdw
Member - Posts: 14
Posted: August 17, 2007 at 8:45 AM / IP Logged
I had an Avital 4100 installed in my 2001 Durango last night. When I push the lock button I get one flash from the parking lights and the doors lock. When I push the button again to unlock I get 2 flashes from the parking lights (all normail so far) and the doors unlock and then I hear the doors try to unlock again right after.
Is this normal???
Thanks,
Scott
swerks
Copper - Posts: 224
Posted: August 17, 2007 at 9:02 AM / IP Logged
this is normal the unit isprogrammed for double pulse unlock
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
JWorm
Platinum - Posts: 2,208
Posted: August 17, 2007 at 9:05 AM / IP Logged
Does the drivers door unlock on the first attempt, and then all of the doors on the second attempt? If so, that is normal.
There are two wires in the truck that control the doorlocks. A WHITE/ green wire that goes to the door lock switch on the drivers door and a lt. GREEN/ orange wire that goes to the key cylinder in the drivers door. If you have a factory alarm, they should have only connected to the lt. GREEN/ orange wire. If they connected to both wires, that could explain the double unlocking.
scottdw
Member - Posts: 14
Posted: August 17, 2007 at 9:40 AM / IP Logged
Cool thanks!!
But this will not hurt anything right???
fkelsey
Copper - Posts: 94
Posted: August 17, 2007 at 9:49 AM / IP Logged
Nope it's supposed to do that
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
