remort start for 07 nissan titan
gabet40
Posted: August 26, 2007 at 11:04 AM / IP Logged
my 07 titan has two starter wires, lt. green, and brown. the remote starter im installing (prestige 785) only has one starter wire, which i attached to the brown. how do i incorporate the lt. green wire to the remote start system?
Thanks in advance.
enice
Silver - Posts: 857
Posted: August 26, 2007 at 11:51 AM / IP Logged
Use a relay , your prestige system may have an additional negative starter output.  If it doesn't then use that starter wire from the 785 which is positve and tag it and connnect to relay.  Do not connect together with the other or  jump it directly to the other.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 26, 2007 at 12:56 PM / IP Logged
Does the Prestege 785 have any negative secondary outputs for starter acc. and ign. ? These would be your triggers for the second starter that is needed. Give that a looksee, if not, then enice has the answer!
gabet40
Posted: August 26, 2007 at 3:51 PM / IP Logged
I found one auxiliary that sends a 300 mA ground output only during the crank. The manual says its sometimes used to activate the 'Crank Low/Bulb Test' in some vehicles or referred to as the ECM wake up wire in other vehicles.
Will this work?
enice
Silver - Posts: 857
Posted: August 26, 2007 at 4:00 PM / IP Logged
if that wire only gives a ground pulse during crank and no other time then yes you would use that on pin 85 of the relay.  86  and 30 to 12v and last you would tag the 87 to the 2nd starter wire.
gabet40
Posted: August 26, 2007 at 4:39 PM / IP Logged
Thanks for your help. i'm more of a visual person so i drew up a little sketch on photoshop of what i think you explained. is there anyway i can send it or post it for you to check? (to reduce and attach it to this reply will make it too small to read)
enice
Silver - Posts: 857
Posted: August 26, 2007 at 7:09 PM / IP Logged
just send me a pm and i'll send you give you my email address
