2007 f 150 supercrew wiring
jrilla
Gold - Posts: 1,498
Posted: August 29, 2007 at 3:08 PM / IP Logged
I am looking for the wiring info for this vehicle. Thank you.
mikvot
Gold - Posts: 1,043
Posted: August 29, 2007 at 6:51 PM / IP Logged
12volts lt. GREEN/ purple (20A) ignition harness
Starter  RED / lt. blue   +   ignition harness
Second Starter  N/A
Ignition  dk. blue/lt. green   +   ignition harness
Second Ignition  N/A
Third Ignition  N/A
Accessory  BLACK/ lt. green   +   ignition harness
Second Accessory  N/A
Keysense  BLACK/ pink   +   ignition harness
Power Lock  pink / YELLOW   -   DKP or BCM, green plug, pin 9
Power Unlock  pink/lt. green   -   DKP or BCM, green plug, pin 1
Lock Motor  pink/black   5wi  DKP or BCM, blue plug, pin 2
Unlock Motor  RED / orange   5wi  DKP or BCM, blue plug, pin 5
Parking Lights+  brown   +   switch or BCM, blue plug, pin 6
Parking Lights-  N/A
Hazards  same as turn signal wires
Turn Signal(L)  lt grn/wht (F), lt grn/org (R)  +   turn signal switch
Turn Signal(R)  wht/lt blu (F), org/lt blu (R)  +   turn signal switch
Reverse Light  BLACK/ pink   +   DKP, gray plug, pin 13
Door Trigger  BLACK/ yel (L), BLACK/ pink (R)   -   DKP, gray plug, pins 22, 23
Dome Supervision  BLACK/ lt. blue   +   DKP, gray plug, pin 6
Trunk/Hatch Pin  N/A
Hood Pin  N/A
Trunk/Hatch Release  N/A
Power Sliding Door  N/A
Factory Alarm Arm  N/A
Factory Alarm Disarm  N/A
Disarm No Unlock  N/A
Tachometer  NOT RED / lt. green or red   ac   any ignition coil or fuel injector
Wait to start  N/A
Brake Wire  lt. green   +   brake pedal switch
Parking Brake  lt. GREEN/ red   -   parking brake switch
Horn Trigger  dk. blue   -   switch or BCM, blue plug, pin 12
Memory Seat 1  BROWN / lt. green   -   memory seat switch on seat
Memory Seat 2  BLACK/ orange   -   memory seat switch on seat
Memory Seat 3  N/A   -
FORD, F SERIES LIGHT DUTY, 2007, Door Trigger
The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each.
The BCM (Body Control Module) is on the driver side rear cabin wall.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
