alarm/remote start 2car and 2 aux chnls?
MasterInstall2
Posted: September 11, 2007 at 12:13 AM / IP Logged
Any product suggestions? I need an 2 alarms with the following capabilities
Remote start
Trunk release
One aux. channel
Also each remote needs to be able to access all functions for both cars.
fbird08
Copper - Posts: 90
Posted: September 11, 2007 at 9:03 AM / IP Logged
You should be able to do that with any of the DEI 4 button or Audiovox 4 button systems. Just when you program the remote to the second car do not use the auto program feature. Program each channel individually and use combinations of buttons IE: (for the second car) lock could be AUX+Lock together, unlock could be AUX+Unlock together, etc. Any combination of two buttons sends a different signal that can be programed as a seprate channel. Hope that helps.
Money is just paper
Power is fleeting
But your word is everything,
If your word means nothing,
You are nothing...think about it
JWorm
Platinum - Posts: 2,208
Posted: September 11, 2007 at 9:51 AM / IP Logged
Compustar 2W900FM-AS
Make sure you get a blue 2-way remote so you can control 2 cars. The white 2-way remote can only do 1 car.
You just hit a combo of buttons (I believe it is III and IV together) and the remote will switch to the other car. The unit will also come with a 1-way remote. I believe it will only be able to be used with one car.
MasterInstall2
Posted: September 11, 2007 at 10:03 AM / IP Logged
Hey thanks you two!  Now if I can only get someone to post wiring diagrams for the 2005 H2 and the 2008 Saturn Sky I will be rockin!
Thanks again!
fbird08
Copper - Posts: 90
Posted: September 11, 2007 at 11:06 AM / IP Logged
I do not have the info for those but you will need to take a lot of the dash apart to do the H2 (I have done a few before, start with the radio trim I believe) and I believe the Sky is not fun electronically (I have never done one, but have heard many complaints about it). Just an fyi.
Money is just paper
Power is fleeting
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
