wire diagram for a 2000 honda civic ex
Mr.T
Posted: February 19, 2003 at 11:29 AM / IP Logged
I'm tring to wire up a code alarm to a 2000 Civic ex I have removed the factory alarm but I can't figure the pinouts, I cannot figure out how connect the new alarm can I use the old factory alarm harness wires? or do I have to trace out all the wires from the power locks, parking lights ect.. are there any wire diagrams around.
Thank you in advance
Mr.T
Platinum - Posts: 12,488
Posted: February 19, 2003 at 11:42 AM / IP Logged
You do not need to remove the OEM security system at all. Plug the OEM system back in and what you can do is splice into the exisiting wires with the wires coming from the Code Alarm. Here is a wiring diagram for the Civic:
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness or *1      |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|GREEN / WHITE         |-  |keyless entry module *2     |
|     POWER UNLOCK|GREEN/ orange        |-  |keyless entry module *2     |
|       LOCK MOTOR|WHITE/ red           |   |drivers kick panel          |
|     UNLOCK MOTOR|blue/red            |   |drivers kick panel          |
|    DISARM DEFEAT|yellow/red          |   |keyless entry module *2     |
| PARKING LIGHTS +|RED / black           |   |keyless entry module *2     |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|lt. GREEN/ red       |-  |OEM alarm plug *3           |
| DOME SUPERVISION|same as doors       |   |                            |
|  TRUNK/HATCH PIN|blue/black          |-  |OEM alarm plug *3           |
|       TACHOMETER|blue                |   |test connector *4           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|gray                |-  |OEM alarm plug *3           |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|RED / yel - RED / blu   |A  |drivers door switch         |
|  RF WINDOW UP/DN|blu/yel - blu/org   |A  |drivers kick panel          |
|  LR WINDOW UP/DN|grn/yel - green     |A  |drivers kick panel          |
|  RR WINDOW UP/DN|yellow - yel/grn    |A  |drivers kick panel          |
Notes:
*1  In 6 pin white plug behind fuse box  *2 The keyless entry module is white in color, and located in the drivers kick panel.  *3 The OEM alarm plug is to the right side of the steering column.  The plug is green.  *4 Drivers side fire wall under hood in a 2 pin plug
