siren chirp
muaiad97
Copper - Posts: 207
Posted: October 01, 2007 at 8:51 PM / IP Logged
hi all
I installed  alarem and starter  command  start  cs-580i fm in acura tl 1996  every thing working good  exept i have one problem the siren dosnt chirp  during lock  unlock and when the alarem is triged but i get the confirmation on the remote that the alarm is triged  if someone open the doors but the sirn dosnt sound  the siren works  manualy i mean when i atached to the battry . i need help pleas
thanx
lsondubz
Copper - Posts: 193
Posted: October 04, 2007 at 12:56 PM / IP Logged
Is the brain giving voltage out on the siren output wire? Have you checked any of your wiring?
sldxstyle
Member - Posts: 6
Posted: October 13, 2007 at 1:12 PM / IP Logged
I have the same problem as well. Any ideas on a fix? Connects seem to look good.
moonliter
Copper - Posts: 322
Posted: October 13, 2007 at 5:38 PM / IP Logged
muaiad97 wrote:
hi all
thanx
Does the siren work when you press the lock or unlock button for > 3 seconds ? If the siren works, then try this press truck button once within 3 seconds press lock or unlock button.
tedmond
Gold - Posts: 4,610
Posted: October 13, 2007 at 6:25 PM / IP Logged
it might be on silent mode, in silent mode, if the car is armed, unarmed, or the alarm is triggered, only the 2 way will be notified, siren will be "muted"
CutDog504
Silver - Posts: 643
Posted: October 14, 2007 at 6:02 AM / IP Logged
Also, make sure you have a good ground on your siren.
