2004 chevrolet express van
mavericknet
Posted: October 09, 2007 at 11:18 AM / IP Logged
I'm looking for the horn-ring wire for splice into for Siren cut-over, as well as the location for the wire attached to #1 spare fuse on the floor fuse panel located under the drivers seat.
Moderator - Posts: 12,488
Posted: October 10, 2007 at 8:22 AM / IP Logged
You can grab the horn wire at BCM, gray plug, pin B9 TAN wire
mavericknet
Posted: October 24, 2007 at 4:06 PM / IP Logged
If the horn RING is B9 on the gray plug on the BCM, then why would there be +12v on the wire without pushing on the horn, if I remove the gray plug, how would I still be able to push on the horn ring and make the horn sound.
I'm looking for the wire coming down from the ring itself mounted inside the steering wheel.
Tuesday, January 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
