fiberglass plenum?
danielhitch
Posted: October 13, 2007 at 8:33 AM / IP Logged
Hi.
Im currently doing some major engine work on my car. I am going to be supercharging it.
I need to make a custom plenum chamber and was thinking about making it from fibreglass as I have no experience working with metal.
My question is, will a fibreglass plenum cope with boost?? Im planning on running 7-12psi on the charger...
Thanks.
tubbs04
Copper - Posts: 212
Posted: October 16, 2007 at 9:05 AM / IP Logged
Plenum chamber??? is that kinda like a flux capacitor??? hahaha, jk.... I honestly have no clue what that part does or how strong it needs to be, but I would suggest using carbon fiber over fiberglass if you need a very strong composite... It will give you better strength then fiberglass but It will cost more... try building one up w/ fiberglass then make the final product in CF.... Then I guess hope for the best... hahaha... good luck!
...don't crush the weasel...
tuscani
Member - Posts: 27
Posted: October 16, 2007 at 11:18 PM / IP Logged
honestly you would be better off paying to have one made for you, it would have to be realtively thick as well as VERY smooth.
not to mention it would be much heavier and wouldn't withstand heat as well.
IMHO, I'd shy away.
Dreadlock
Copper - Posts: 55
Posted: November 20, 2007 at 4:24 PM / IP Logged
Absolutely not. Don't waste your time.
bellsracer
Silver - Posts: 703
Posted: December 07, 2007 at 2:54 AM / IP Logged
FG can take a lot of pressure but it is not reasonable designed to work as a plenum for a supercharged motor. The vibrations, heat, and heavy pressures from the SC will make this a unwise choice, particularly over 7 lbs of boost.
Another major concern is maintaining perfectly clear and smooth inner surface to the plenum. Minor flaws and loose particles as time goes on could end up inside the motor and sending you out for a new longblock at the very least.
What vehicle are you planning on, or better yet, what's your motor? There might be someone here who could get you the information you are looking for, if not me.
Ganbatte ne!
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
