2005 dodge caravan remote start
henrylfair
Member - Posts: 25
Posted: October 20, 2007 at 1:48 PM / IP Logged
Do anybody know the easiest place to connect to the tach wire or oil sense wire cant get a good tach signal
Henry Fair
Twelvoltz
Platinum - Posts: 2,384
Posted: October 20, 2007 at 3:49 PM / IP Logged
Use a fuel injector, they will have a common colored wire at each use one of the odd colored wires at any injector.
henrylfair
Member - Posts: 25
Posted: October 20, 2007 at 5:53 PM / IP Logged
hey direction on here say use pin 21 for parking lights - activation but installer software say to use WHITE/ orange wire and it is +activation anyone knows which is correct
Henry Fair
Twelvoltz
Posted: October 20, 2007 at 6:21 PM / IP Logged
For positive trigger parking lights DEI shows the WHITE/ orange as the right side only with a WHITE/ brown for the left side located in the driver's kick, harness to the rear.
They list the WHITE/ brown negative through a 2.1k resistor isolated from the switch.
henrylfair
Member - Posts: 25
Posted: December 30, 2007 at 12:11 PM / IP Logged
Can any one give me suggestions on remote start that works well with the dodge Grand caravan in price range of $100- $200 i will be using the XK532 interface module
Happy New Years to All!!!!!!!
Henry Fair
henrylfair
Member - Posts: 25
Posted: December 31, 2007 at 9:11 PM / IP Logged
Do any one know if you still need to use the door triger resistor when interfacing with XK532 or do the XK532 handle the door unlocking and locking witout the resistors
Henry Fair
tonyberg
Copper - Posts: 116
Posted: December 31, 2007 at 9:12 PM / IP Logged
it handles the lock unlock withOUT resistors
henrylfair
Member - Posts: 25
Posted: December 31, 2007 at 9:24 PM / IP Logged
ok thanks were can i get the oil pressure or alternetor wire on 2005 dodge grand caravan also the best way to glab the parking lights wire
Henry Fair
tonyberg
Copper - Posts: 116
Posted: January 01, 2008 at 11:45 AM / IP Logged
i am unsure of the oil pressure or alternator wire...if you are just looking for a tach signal you can utilize the blue wire with a stripe at the back of the coil packs.   Parking lights are WHITE/ orange in the driver kick panel , they are positive here
henrylfair
Member - Posts: 25
Posted: January 12, 2008 at 11:21 AM / IP Logged
can any one help me out the xk532 say hook the data wire up to the white and orange wire on the skim but their only four wire and neither wire is white and orange
Henry Fair
