2002 ford expedition with mach stereo
zero signal
Posted: October 22, 2007 at 11:05 AM / IP Logged
Hello there!  I'm still tyring to find the wiring color code for a 2002 Ford Expedition equipped with the Mach stereo system.
I have already installed door speakers in this vehicle, so I know what color the wires going to the actual speakers are.  However, it is my understanding that the Mach stereo has a factory amp that powers all the door speakers.  I need the color code for the wires between the factory head unit and the amp.
I'm installing a Kenwood 617DVD and Navigation package.  Crutchfield sent a wiring adapter with literally about 30-ft of wire attached to it.  I want to install the receiver "box" inside the center console and wire everything up behind the in-dash unit, utilizing the stock wiring and the stock Mach amplifier.  However, I don't know what is what with this stero system.  There are 3 plugs that connect to the factory head unit.  I've looked at 3 different wiring harness adaptors for this vehicle, and none of them have the correct plug configuration.
I'm baffled. 2002 ford expedition with mach stereo - Last Post -- posted image.
ranthony
Member - Posts: 7
Posted: December 03, 2007 at 6:58 PM / IP Logged
2002 ford expedition with mach stereo - Last Post -- posted image.is this the part your looking for? it's from best kits #bha5700
techman93
Silver - Posts: 591
Posted: December 03, 2007 at 7:05 PM / IP Logged
Battery             WHITE/ VIOLET     (+)          RADIO HARNESS
Accesory        BLACK/ PINK     (+)          RADIO HARNESS
Ground             BLACK/ GREEN     (-)          RADIO HARNESS
Illumination     BL/BLACK     (+)             RADIO HARNESS
Power Antenna          AMP=BLUE
LF Speaker (+)          WHITE/ RED
LF Speaker (-)          BROWN
RF Speaker (+)          GREEN
RF Speaker (-)          WHITE/ ORANGE
LR Speaker (+)          LIGHT BLUE/BLACK
LR Speaker (-)          YELLOW
RR Speaker (+)          PPL/WHITE
RR Speaker (-)          LIGHT BLUE
Radio Security          YES
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
