1999 izuzu rodeo, window wiring
phatty34
Posted: October 23, 2007 at 11:58 AM / IP Logged
does anyone have a wiring diagram for a 1999 izuzu rodeo LSE  I need the diagram especially for the master control switch for the power windows.thanks in advance
Twelvoltz
Platinum - Posts: 2,384
Posted: October 23, 2007 at 3:18 PM / IP Logged
Here is what Audiovox lists:
          #1491: 1999 ISUZU RODEO 4DR SUV
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / WHITE          (+)          RADIO HARNESS
     Accesory          RED / YELLOW          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          GREEN/ RED          (+)          RADIO HARNESS
     Dimmer          RED / YELLOW          (+)          RADIO HARNESS
     LF Speaker (+)          BLUE
     LF Speaker (-)          YELLOW
     RF Speaker (+)          GREEN
     RF Speaker (-)          GRAY
     LR Speaker (+)          ORANGE
     LR Speaker (-)          WHITE
     RR Speaker (+)          ORANGE / BLUE
     RR Speaker (-)          ORANGE / WHITE
     Amp Location          NOT LIKELY
     Radio Security          YES
     Security
     Battery          WHITE/ BLACK          (+)          OR WHT SWITCH HARNESS
     Ignition 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          RED / GREEN          (-)          DRIVERS KICK WHT PLUG
     Trunk Trigger          BLUE/DARK GREEN          (-)          LIGHT IN TRUNK
     Alarm Disarm          YELLOW/BLUE          (-)          DKP WHT PLG, PULSE AT SAME TIME AS UNLCK
     Alarm Arm          PPL
     Parking Lights          GREEN/ RED          (+)          DR. SIDE KICK PANEL OR SWITCH
     Convenience
     Headlights-Lo          RED / BLUE          (-)          AT HEADLIGHT SWITCH
     Wipers-Lo          BLUE / YELLOW          (+)          STEERING COLUMN
     Trnk Release          RED / BLUE          (+)          SWITCH ON DASH
     Remote Start
     Ignition 2          BLACK/ RED          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BLUE          (+)          OR BLU/BLK IGNITION SWITCH HARNESS
     Anti-Theft Descript          NONE
     Key Sense          RED          (+)          IGNITION SWITCH HARNESS
     Tachometer          BLACK/ RED          (-)          DRIVERS KICK 22 PIN PLUG
     Speed Sense          BLUE/BLACK          (AC)          DRIVERS KICK 22 PIN PLUG
     Brake Lights          RED          (+)          AT BRAKE SWITCH
     Horn          GREEN          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          RED / BLUE          (-)          DKP WHT 22 PIN CON W/ DISARM
     PowerLock          LIGHT GREEN/ RED          (-)          NEGATIVE TRIG KEYLESS ENTRY
     LF Window Up          LF:BROWN / WHITE
     RF Window Up          RF:BROWN / WHITE LR:BROWN / WHITE RR:BROWN / WHITE
     LR Window Up          LF:BROWN / RED
     RR Window Up          RF:BROWN / RED LR:BROWN / RED RR:BROWN / RED
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Posted: October 23, 2007 at 5:38 PM / IP Logged
If I remember, some of these used a data link from drivers window, just like Mits and you have to wire out to each motor. You can't pick them all up at driver's door.
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
