ion door locks
martinrp
Posted: October 31, 2007 at 5:41 PM / IP Logged
I am wiring an alarm in a 2004 Saturn Ion and I needed assistance with the door lock/unlock.  I read that it is a one wire system with lock being a negative trigger and unlock a negative thru a 1.5K resistor.  Can I just hook up the negative lock from the alarm to the cars white wire and hook up the unlock wire from the alarm to the white wire with the resistor?  Do I need to put a relay?  If I need to put a relay does someone have a wirring diagram that I can follow?  Thanks
rpm
KarTuneMan
Platinum - Posts: 7,056
Posted: November 02, 2007 at 8:50 AM / IP Logged
You should NOT need relays. If it then, does not work..... wire up some relays.
Heres a diagram from audiovox for the relay setup
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
