4th order bandpass boxes
jmelton86
Gold - Posts: 1,228
Posted: November 08, 2007 at 12:44 AM / IP Logged
holdinmyown wrote: the bass reflex design is only about 8-10 db higher than that of a plain sealed chamber.
Only? 8-10dB's is dramatic!
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
jmelton86
Gold - Posts: 1,228
Posted: November 08, 2007 at 12:46 AM / IP Logged
That is, if you know what you're talking about. It doesn't seem like you do, though.
Big3 in 1/0G
1/0G to GTO14001
aznboi3644
Gold - Posts: 2,600
Posted: November 08, 2007 at 12:53 AM / IP Logged
sealed boxes have a q factor...but no tuning
i still don't know what you are talking about
holdinmyown
Member - Posts: 8
Posted: November 08, 2007 at 3:35 PM / IP Logged
I must have gotten some misinformation on the web then about the differences. Q factor is the magnitude that the box amplifies or cuts the frequencies, correct? Then I suppose what I was trying to get at is, would it be ok to have the sealed chamber boosting a different range of frequencies than the vented chamber is tuned to?
If it is fine then answer this question. Typically what frequency does high bass start to drop off and low mid range start to pick up, or the ideal crossover frequency between those ranges. The box I designed, when I finally got the cone excursion within acceptable range the maximum spl is 135 at 95Hz. This box design, at least on paper, dominates over all others with this particular sub on the spl chart, the cone excursion chart, the transfer function magnitude chart, but it of course has some group delay.
Also how do I reduce the air velocity in the ports, its 20m/s.
sonofthor
Member - Posts: 12
Posted: November 08, 2007 at 8:50 PM / IP Logged
reduce air velocity? try longer ports. Of course, this changes your tuning as well..
holdinmyown
Member - Posts: 8
Posted: November 08, 2007 at 9:11 PM / IP Logged
what about those other questions i had?
stevdart
Platinum - Posts: 5,816
Posted: November 08, 2007 at 9:21 PM / IP Logged
First, reducing air velocity is all about having larger port opening space.  Use the program to work with some different port opening sizes while keeping tuning freq where you want it to be.  Also, be sure that you are looking at air velocity within the range of audio frequencies that you will likely be listening to in real life (for example, a high velocity at 20 Hz means nothing...where does it hit at 35 Hz?)
Design your bandpass box with the wisdom that you will be changing it a few times to get what you are looking for in sound and performance.  Meaning this:  experiment with unfinished boxes and design your project so that you may make size changes without having to start from scratch each time.  An experienced designer may find a perfect combination of a particular driver and a particular placement in a particular vehicle....but then find that it doesn't work out quite as well in a different vehicle.  Time and patience are your allies when dealing with bandpass, else you end up with something that sounds no better than a prefab that you can pick up at a store.
If your sealed design is "boosting" a range of frequencies, this is a high Q.  You will see that the rolloff is steep as well.  If there is no peak and the rolloff is gradual, you will note that the Q is likewise lower.  Car audio sealed tends toward high Q for a couple of reasons:  limited space for large enclosures, and the desire for booming bass in today's music climate.  Your bandpass needs a marriage of the sealed side with the vented side to produce the sound you are looking for, so prepare for some experimenting.  In other words, with bandpass there quickly must come a time for hands-on building and forget worrying about  logic and assumptions.
And note also, if you want maximum SPL you will want your target to peak in the 50 to 60 Hz range, not 95 Hz.  Your vehicle resonance plays a huge role in this.
holdinmyown
Member - Posts: 8
Posted: November 08, 2007 at 9:31 PM / IP Logged
Nice... thats really helpful, I'll try and go back and change some things around. What frequency would you consider the end of the line for bass?
stevdart
Posted: November 08, 2007 at 9:45 PM / IP Logged
Bass goes to midrange at about 400 Hz, but the majority of bass is handled by your front mid drivers.  Sub bass goes up to 80 Hz, maybe up to 100 Hz.  You are dealing with only sub bass with your enclosure.  Try low pass at 80 Hz for your sub, high pass at 80 Hz for the front components.  At that crossover point, sub bass starts dropping off steeply just above 60 Hz, maybe a little higher.  Use  the filters tool in your design software to generate a low pass crossover, 4th order (match the crossover alignment that your amp has).  Click it on and off and watch how the high end of the sub bass drops off.
ibasspro
Copper - Posts: 95
Posted: November 12, 2007 at 9:59 AM / IP Logged
holdinmyown wrote:
man... read my posts. the rear chamber is 64hz, and the front chamber with the port is 80hz, together the box as a whole will generate some mean notes as long as theres not something I don't know about yet... plus I've built plenty of plain sealed and vented and I want to step it up. So if anyone has built these in the past and has some good tips I'd like to know them.
dude your post states 16Hz. & you wanna "step it up" from ported boxes? Here is a quick lesson as to why BP boxes came into being. Size. back in the day, a 12" sub would require about 7 cubic feet of air space for a ported box, & would not perform well sealed with low freq. unless a large box was used, but then power handling was sacrificed. Also, with a BP box, the only sound you hear is the port tuning, you do not hear the distortion coming from the sub, & because of this cheap sub makers started using them to make their cheapy subs sound better....the down side, is you do not hear the sub crying for mercey.
Now, those BP boxes could be made smaller by sacrificing a smooth responce, for being efficient at 1 freq. or 1 group of freq...& depending on the box, a freq. & it's octave. i.e 40Hz & 80Hz., but there is a lul in the output between those freqs., & the rolloff is quite steep, so 30Hz is prob. 7-10db down from the peak freq. in our 40Hz example
Those that posted above are correct, 80Hz (or around there) is a proper x-over point for a sub, never in a car audio subwoofer application should freqs. above 120hz ever be used. all it does is muddy the sound, make the bass directional, & lowers power handling of the sub.
Here is some solid advice. Post up here what kind of car you have, & maxximum box dimentions you can have, & see what some of us come up with for ya. I would almost bet for output most will make a big slot ported box, & if you want accuracy, most would make a moderate sized sealed.
So, post car, year make model, Amplifier model #, & rated output
Size & model # of sub, as well as how many you are using
& size restrictions
A little more advice, be nice to those you are asking for help, & they will give better answers. Now give an apple to the teacher.....sucka LOL
used to be loud, used to be fast...now I am married LOL
