ported box in a 92 silverado single cab
evileagletalon
Copper - Posts: 65
Posted: November 02, 2007 at 1:50 PM / IP Logged
I have (3) 10" JL W3 v2 that I was thinking of putting in my truck. I want to do a ported box which means that I will have to try this with only (2) of them.
I no longer have a bench seat, I have 2 power bucket seats out of a 99 Yukon. I don't have a center console either, which means more room to work with.
Each woofer needs 1.125cu ft for a ported enclosure. The port needs to be 1.25" X 10.5" for the port opening, and 24.875" for the port length. By these specs, this box should be tuned to 33hz.
What would be the best way to build a box for (2) w3s ported in my truck?
I want to be heard from far away also.
These (2) subwoofers will be powered by my Zapco Reference 750.2
ibasspro
Copper - Posts: 95
Posted: November 02, 2007 at 8:15 PM / IP Logged
Post the T/S parameters for the subs, & make so accuate measurements of the area you have to work with (WxHxDtop&Dbottom), & I will poke em into TP & see if we can make all 3 work for ya.  Also. A 750 is to much to the 2 JL's unles you really gain it down. I just looked, & I only have the 12" vrsion of yer subs, so make shure to give all the specs JL lists in te owners manual, in mm if you can.
used to be loud, used to be fast...now I am married LOL
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
