1990 nissan pickup cruise addition
deneyses
Member - Posts: 6
Posted: November 02, 2007 at 9:30 PM / IP Logged
I have installed tons of stereo equipt and other auto stuff, but never a cruise control.  I was wondering if someone could recommend an aftermarket unit for my 1990 Nissan Truck manual 2wd and any install tips.  thanks
airandsound
Copper - Posts: 69
Posted: November 21, 2007 at 11:33 AM / IP Logged
scsfrigette cruise works great on the Nissan PU.
Smooth and reliable.
sparkie
Platinum - Posts: 2,061
Posted: December 28, 2007 at 7:31 PM / IP Logged
Rostra makes an excellent cruise. If you have never done one before, I suggest having it professionally installed. There are many things to be concerned with. The most serious concern is with the throttle linkage. If it is done wrong, it could cause the throttle to jam open and this wouldn't be good. If you want to try it, read the install manual thoroughly first. Rostra has a very good manual.
sparky
ranger svo
Copper - Posts: 70
Posted: December 29, 2007 at 9:10 PM / IP Logged
I agree with sparkie. I like the Rostra electronic cruises. 250-1316
If your dealing with a 4-cylinder motor and many of those trucks were, pedal pull is recommended. I've done about  20 or 30 of those trucks over the years. If you get a 250-4244 throttle adapter (I know its a Toyota adapter) discard everything but the linkage adapter. It will fit the NIssan with just a little touch up with a dremel.
This will move your linkage away from anything that might cause a hang up. Besides I would rather have my teeth pulled or a root canal than do a pedal pull.
Well thats my 10-cents worth.
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
