07 tacoma, clifford 50.0x
taco70
Posted: November 06, 2007 at 2:25 PM / IP Logged
hello I am a noobe here and I just got my new clifford 50.0x.
I want to install this on 07 tacoma DC without the remote start(I just want to use the alarm).
my questions are:
1. which connectors do I have to connect or not connect (H1,H2,H3,H4,door lock, remote start).
2. well if I want to use the remote start, is DEI 1100x will work for 07 tacoma and I dont want to use my spare key.
3. Does anyone has the wire diagram for 07 tacoma DC. I researched and found it for the 05.
taco70
Posted: November 06, 2007 at 2:26 PM / IP Logged
any help would appreciated.
Thank you
profuse007
Gold - Posts: 2,015
Posted: November 07, 2007 at 11:31 AM / IP Logged
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE/ RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK/ RED          (+)          IGNITION SWITCH HARNESS
     Starter 1          GREEN/ BLACK          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BLUE          (-)          AT FUSE BOX BLACK 13 PIN PLUG PIN 9
               YOU MUST DIODE ISOLATE THESE TWO WIRES TO MONITOR ALL DOORS.
     Domelight Super          BLUE          (-)          AT VEHICLE FUSEBOX
     LF Latch          GREEN/ YELLOW          (-)          AT BECU 18 PIN PLUG PIN 7
               MUST DIODE ISOLATE EACH WIRE
     RF Latch          RED / BLACK          (-)          AT BECU 22 PIN PLUG PIN 8
     LR Latch          PINK/BLACK          (-)          AT BECU 18 PIN PLUG PIN 6
     RR Latch          PINK/BLACK          (-)          AT BECU 18 PIN PLUG PIN 6
     Alarm Disarm          DISARMS WITH UNLOCK          (-)          IGNITION SWITCH HARNESS
               THIS IS THE KEYSENCE WIRE, (-) TRIGGER WILL DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
     Alarm Arm          ARMS WITH LOCK
     Parking Lights          GREEN          (+)          AT VEHICLE FUSE PANEL
     Low Crr Pk Lights          GREEN          (-)          AT LIGHT SWITCH
     Ignition 2          BLUE / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          WHITE/ GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 2          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     Key Sense          GREEN/ BLACK          (-)          IGNITION SWITCH HARNESS
               PULSE WITH GROUND DURING REMOTE START WILL DISARM FACTORY ALARM
     Tachometer          BLACK/ WHITE          (AC)          AT DATA LINK CONNECTOR UNDER DRIVER DASH PIN 9
               18 PIN PLUG - PIN #10
     IMO          LIGHT GREEN/ BLACK
     IMI          BLUE/WHITE
     Modules
     WIRE          LOCATION
     Module 1          THE BODY ECU IS ATTATCHED TO THE BACK OF THE FUSE BOX
     Doorlocks/Windows
     Power Unlock          GREEN/ BLACK          (-)          DRIVER KICK
               DOUBLE PULSE
     PowerLock          VIOLET          (-)          DRIVER KICK
Houston,TX
