dodge caravan 1996 car alarm
dodgefinland
Posted: November 06, 2007 at 11:37 PM / IP Logged
Hello everybody!
can somebody help me with door lock/unlock wire.
Car is Dodge caravan 1996 3,3l SE.
I canīt found the wire indicated in the Caravan at the BCM for the lock/unlock wire which was WHITE/ Light Green strip.
there is two 40-pin connector at bcm.  what pin number is door lock/unlock wire.
really need help!
Twelvoltz
Platinum - Posts: 2,384
Posted: November 07, 2007 at 7:35 AM / IP Logged
My notes have it listed as the WHITE/ green (not WHITE/ light green) in plug on the left, bottom of the fuse box. I do not have a pin number listed so it must be pretty distinguishable.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 07, 2007 at 8:29 AM / IP Logged
There are 2 WHITE/ lt.green on the plug. 1 at the end of the plug (not the one you want) and 1 towards the middle of the plug, (the one you DO want) next to a WHITE/ dk.green.
dodgefinland
Posted: November 07, 2007 at 2:47 PM / IP Logged
Thanks!
I found correct wire.
BCM plug left - pin 45  - door lock
BCM plug left - pin 79 - door trigger
BCM plug right - pin 2 - dome light
