More Autostart AS-6165 questions...
talon1001
Member - Posts: 10
Posted: February 22, 2003 at 10:06 AM / IP Logged
Hey i think i have this thing made, but i have a couple more questions, does any one know what colour and the where abouts of the heater blower motor wire on a 91 Dodge Daytona? I believe i hook that up to the "Accessories" output from the alarm, thats what the instructions say anyways. My next question is; there is a green wire on one the the alarm harnesses that says it connects to the 5th relay, i was wondering if anyone new what that meant. Ok the last one I promise, hopefully, In the vehicle wiring database for the car there is a ignition and a ignition 2, which one of those do i use? Thanks in advance and sorry about the simple questions.
Jesse
Moderator - Posts: 12,488
Posted: February 22, 2003 at 4:51 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|ORANGE / purple       |*1 |drivers kick panel          |
|     POWER UNLOCK|pink/purple         |*1 |drivers kick panel          |
| PARKING LIGHTS +|BLACK / YELLOW        |   |low in drivers kick         |
| PARKING LIGHTS -|pink/dk. blue       |   |headlight switch            |
|       HEADLIGHTS|ORANGE / white        |-  |headlight switch            |
|     DOOR TRIGGER|yellow              |-  |drivers door pin            |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|lt. GREEN/ orange    |-  |drivers kick                |
|       TACHOMETER|BLACK/ gray          |   |ignition coil               |
|       BRAKE WIRE|WHITE/ tan           |+  |brake switch                |
|     HORN TRIGGER|Dk. GREEN/ red       |+  |horn relay *2               |
|           WIPERS|BROWN / white         |+  |wiper switch                |
|  LF WINDOW UP/DN|white - lt. blue    |A  |in drivers door             |
|  RF WINDOW UP/DN|pur/wht - brn/wht   |A  |in drivers door or dkp      |
Notes:
*1 Some models are 5-wire (type C) and some are 3-wire (type A). Test to identify.  *2 Horn relay is at the bottom of the fuse box.
The GREEN wire will be a (-) trigger ( CHECK TO MAKE SURE OF THIS IN THE MANUAL ) this is your second ignition wire that opens a relay to engage the 2nd ignition wire. Check the manual for the characteristics of this wire to ensure that this is infact a low level (-) activation wire for the relay.
Monday, September 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
