removing sony wxc570r
nickb20
Member - Posts: 17
Posted: February 22, 2003 at 10:43 AM / IP Logged
help, can someone tell me how to remove the sony wxc570r headunit from the dashremoving sony wxc570r -- posted image.
Do it LOUD, fast and furious
Moderator - Posts: 12,488
Posted: February 22, 2003 at 4:52 PM / IP Logged
You will need two keys that come witht he unit. The Sony deck will have one tab on the upper top right  and lower left that needs to be depressed to release it from it's cage.
esmith69
Gold - Posts: 1,511
Posted: February 22, 2003 at 7:29 PM / IP Logged
That's the double din unit, right?  What kind of vehicle is it installed in?  You might actually have to unscrew stuff, but it depends on the vehicle.
nickb20
Member - Posts: 17
Posted: February 23, 2003 at 8:18 AM / IP Logged
I have it installed in a 1999 toyota celica sr.
esmith69
Gold - Posts: 1,511
Posted: February 23, 2003 at 11:41 AM / IP Logged
There should be four screws, two on each side of the radio, that hold the factory brackets in.  These brackets are attatched to your radio via another 2 screws on each side.  You'll need to remove some of the trim panels to get to the bracket as it is hidden underneath the radio trim.  I forgot exactly where all the screws are.  There actually might not even be any, it just might pop out using little clips.  If I had a picture of the dash I could tell u right away what to do.
Tuesday, November 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
