rear defogger/defroster with remote start
memphis2k
Member - Posts: 19
Posted: November 12, 2007 at 2:41 PM / IP Logged
Hello,
I have a 2001 Nissan Maxima with a AstroFlex AstroStart 5204 and I'm trying to figure out how to hook up the (manual HVAC) rear defroster to my AstroStart.  I'm mostly concerned how to hook up the 'car' part.  Relay needed?  Pulsed neg?  Latched??
But some .02 on how to hook up the astro start would be nice.
I have channels with the remote start.  I do have an extra manual climate control unit to monkey with.
Included is a wiring diagram.
rear defogger/defroster with remote start -- posted image.
profuse007
Gold - Posts: 2,015
Posted: November 12, 2007 at 3:00 PM / IP Logged
Youll need a constant/time/latch ~200mA(-) to the GREEN/ Red at the coil of the "rear window defogger relay."
Houston,TX
memphis2k
Member - Posts: 19
Posted: December 20, 2007 at 3:18 AM / IP Logged
Which of these will get me a constant/time/latch??  Any ideas?  I just scanned this from my AstroStart 5204 installation manual.  No, I didn't install it, but I'm trying to tweak it by hooking up the rear defroster.  No where in my manual does it say ~200mA.  Just need a lil advice.  Do I need a relay?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 20, 2007 at 9:53 AM / IP Logged
program level 7 as Utility 1      2,3,6,8,9, up hit the brakes. put them down, hit the brake again.
THEN goto level 11 (utility programing) program utility 1 for 8 min.   1,2,4, and6 up. Hit the brake, put them down, hit the brake....done.
You have programmed the white wire to latch for 8 min. to do your defrost.  (p2-15)
No relay is needed.......
Let me know if you need any other assistance.
KPierson
Platinum - Posts: 3,527
Posted: December 20, 2007 at 10:21 AM / IP Logged
It looks like you can hit pin 14 of the smart entrance unit with a short ground pulse to simulate actually pushing the button.  This way, the rear defroster would shut off under its normal shut down guidelines (temp, time, whatever it uses).
I always prefer using switch side of controls rather then relay side because you will end up with a better simulation of how the car operates if you mimic the controls rather then just drive the relays.
Kevin Pierson
memphis2k
Member - Posts: 19
Posted: December 21, 2007 at 2:12 AM / IP Logged
Thanks both of you for your input!
Just a side note, I can really only use one (first) output on my 2 way LCD 4 button remote, i have a spare 2nd remote that has 6 buttons and works with outputs 1-4.  And yes, so far my defroster works on Pin 14 like KPierson described.
My newest question is:
(A lil off topic) My installed hooked up my outputs (3/4) to the key cylinder locks/unlocks and I just figured it out now.
but when I unlock my car door (armed) with the key, it sets off my car alarm.  This doesn't bother me but I'm just trying to figure out if I need these cylinder switches taking up my ouputs.  Wondering if this is the right way, or something is wrong.  Idealy, I gotta switch output 1 to 4 so I can reclaim my defroster on output 1 with my LCD remote.
KPierson
Posted: December 21, 2007 at 8:50 AM / IP Logged
With your outputs hooked to the key cylinder wires you SHOULD be able to raise and lower the windows if your outputs are set to validity (output signal as long as you hold the button down).
There is NO way on most alarms to disable the aftermarket alarm with the key.  If there was, this would be a huge security flaw (just like the security gap that Nissan includes in most of its vehicles right from the factory).
I'm not sure I would put the defroster on a dedicated output.  I think I would hook it up to the starter output or something so it automatically comes on every time you remote start the car.  I doubt it will hurt anything, and how often do you remote start when it is warm out?
Kevin Pierson
memphis2k
Member - Posts: 19
Posted: December 21, 2007 at 12:21 PM / IP Logged
But what I don't get is how door key cylinder look/unlock has to do with raising & lowering the Windows?  Only thing I can think would be after your car is running, take out the key, and you could still have access to the windows.  I guess its not setup the way you described above and I could reclaim my outputs huh?  As far as I know, I would need a device to raise and lower the windows.  Not really a big deal.
Yep, thats what I thought about the unlocking with a key, shouldn't ever be an issue.
Last question,
ACTIVATE / CANCEL LOW TEMPERATURE MODE
My 4 button LCD remote can send this command, but no where in the installation does it say anything about this.  Its gotta be an output right?  Hmm don't see it listed in my Prog. Outputs listed above.
KPierson
Posted: December 21, 2007 at 12:33 PM / IP Logged
Some newer alarms have onboard temp sensors.  If the car  gets below a certain temprature it will start the car to heat it up.
On a lot of newer Nissans you can raise and lower the windows with extended (-) triggers on the lock and unlock wires.  To test this out on your car, insert your key in the key cylinder and turn and hold it in the 'unlock' position.  The windows should lower, if your specific car has this feature.  If they go down, you can raise them back up by turning and holding the key in the 'lock' position.
Kevin Pierson
KarTuneMan
Posted: December 21, 2007 at 1:03 PM / IP Logged
The Astro has the temp control built in.... on/off, as well as temp setting, and run time!
