alarm/remote start, 2008 civic si
cbr600f2
Member - Posts: 7
Posted: November 14, 2007 at 11:20 AM / IP Logged
2008 Honda Civic Si Coupe w/o Factory Navigation.
Viper 5900 Alarm with DEI 556UW Immobilizer Bypass
Neutral Safety Switch 689M
Backup Battery 520T
Tilt Sensor
Lets start with the questions.
Neutral Safety Switch:
Green (-) Door Trigger | Where does this wire connect to?
Purple (+) Door Trigger | Was told not to use this?
White Tach | Do I need to use a diode/fuse or anything to connect to the fuel injector?
BLACK/ White (-) Neutral Switch | Connected :)
Dark Blue (-) Gnd In | Where does this go on the Car starter?
Light Blue (-) Shut Down Before Remote Start | Do I need this?
Gray handbrake | connected :)
Yellow ignition | connected :)
Red battery | connected :)
Black ground | connected :)
689M Relay
Red (+) Brake Pedal Wire | Which wire on the brake pedal do I connect?
Blue (-) Park/Hand Brake | Connected :)
White -> goes to gray wire on 689M
Black -> taps into Dark Blue wire (requires what kind of diode though?)
Clutch Pedal
Purple -> connected to the colored wire (correct?)
Black -> connected to black wire (correct?)
556UW
Red -> 12V Constant | connected :)
Black -> Ground | connected :)
Blue -> Status Ouptut | connected :)
520T Backup Battery
Red -> To Battery | connected :)
Black -> To Battery | connected :)
Gray -> Constant Power to the Brain Module | connected :)
Blue -> Instant Trigger Input to the Brain Module | Which wire is this???
Black -> Chassis Ground | connected :)
507M Tilt Sensor
Red 12V constant | connected :)
Orange (-) Ground-When-Armed Output | connected :)
Blue -> Instant Trigger Input of the Brain Module | Which wire is this???
I will be posting more questions in a bit for the brain connections itself.
cbr600f2
Member - Posts: 7
Posted: November 14, 2007 at 11:29 AM / IP Logged
Relay Satellite Unit
Purple Starter Side | connected
Green Key Side | connected
Orange accessory | connected
Pink/White | Not Used ??
RED / White 12 constant | connected
Pink ignition | connected
Ribbon Cable | connected
Blue Status Output | connected to 556UW Immobilizer
Orange | do I need this?
Violet | do I need this?
Pink | do I need this?
Brain Unit
H4
Brown Horn | connected to orange wire above steering wheel
ORANGE / Black | do I need this?
Door Lock
Green (-) lock (+) unlock | not sure ?
Blue (+) unlock (-) lock | not sure ?
H3
BLACK/ White | connects to 689M wire
Violet/White | connects to tach wire on 689M to fuel injector (do i need to fuse/diode it?)
Brown (+) Brake Shutdown input | which wire does this go to?
Gray (-) hoodpin shutdown input | connect to hoodpin wire? diode?
Blue/White 200mA defogger/2nd status | where do I connect this?
H2
Light-GREEN/ Black (-) factory alarm disarm | not connected
Gray/Black | Not Used ???
GREEN / WHITE factory alarm rearm | not connected
Violet/Black | Not Used???
WHITE/ Black | Not Used???
Light Blue (-) 2nd unlock | Not Used???
H1
RED / White channel 2 validity output | Which wire?
Red 12v Constant | connected :)
Brown (+) Siren Output | not connected yet
Empty
Black (-) Ground Input | Does this go to the 689M module?
Violet (+) door trigger | Not Used???
Blue (-) Trunk Trigger | Which wire?
Green (-) Door Trigger | Which wire?
Black?White (-) domelight output | which wire? diode? fuse?
WHITE/ Blue activation input | which wire?
White (+/-) parking light output | which wire? diode?
Orange ground when armed | Connected to 507M tilt sensor - anything else?
Thanks so much for your help!
cbr600f2
Member - Posts: 7
Posted: November 14, 2007 at 3:53 PM / IP Logged
I'm trying to understand when they are telling me what wires to tap into on the MICU, do I look behind the MICU or in front? This is for a '08 Honda Civic Si w/ Viper 5900 alarm.
Thanks!
cbr600f2
Member - Posts: 7
Posted: November 15, 2007 at 12:27 AM / IP Logged
I got just about everything except the hood pin and the 2 wires for the factory alarm re-arm/dis-arm. I tried ORANGE / brown on the harness, but neither of them showed changes while arming/disarming the vehicle.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 15, 2007 at 1:28 AM / IP Logged
Do you have any install history?
It would seem to me that you are lost? And thats ok, but......The reson for this comment is on the install manual there are indepth descriptions of what each wire is supposed to be connected too. Then YOU take that info and look at a tech sheet for the car, and find the corosponding wire that does what is described from the install manual.
Which supplier did you get your tech information from?  (directechs, wiremagic.....etc?)
I understand there is no better way to learn than to simply dive in.  Arm, look for it to pi=ulse negative when you turn the key in the door lock, same with disarm. Don't test with the factory transmitter, or the lock button on the door.
07mustanggt
Copper - Posts: 89
Posted: November 15, 2007 at 9:59 AM / IP Logged
For the door trigger wires. You will just use one or the other. If your car is (-) use (-)trigger. IF (+) use (+) trigger. Cut the other wire you don't use.
Tach wire go directly to the fuel injector, no diodes or relays should be needed.
Relay sat ribbon, cut pink/white wire unless your car has a 2nd ignition, I don't think it does though.
relay ribbon cable 4 plug wires. You don't need the orange, violet, pink wires, just cut unless you add extra sensors ie motion, tilt, etc.
h4 dont need ORANGE / black wire cut it
door lock wires. You need to look on the tech sheet and see if the car is - or + then connect wires accordingly
h3 violet/white connect to tach, don't need a relay or diode. +brown goes to cars brake pedal(shuts down remote start when brake is pressed) again look on tech sheet for correct wire color.   Hoodpin wire, I used the actual hoodpin that came with my alarm. Run wire to it. Test the cars hoodpin wire to make sure its (-). mine didn't work so thats why I used the separate hoodpin. Blue/white can be used to run your rear defogger if you live somewhere cold. look at tech sheet.
h2 I didn't connect any of these wires on mine. If you have a factory alarm you need to connect fact. disarm and arm wires.
h1 RED / white is a trunk release, tag trunk release wires on car. brown goes to red siren wire, black goes to ground, not the 689m Ground it to the car under a factory bolt...just look for an existing ground and use that spot. violet or green + or - door triggers of car. blue is trunk trigger, BLACK/ white dome super use relay if you decide to hook it up, not necessary though. WHITE/ blue not used, white goes to parking lights. IF its + or - you have to change the jumper on the brain to the right polarity. orange dont use or just leave on tilt sensor.
Hope this helps you out. I just did a python 990 on my 07 mustang. this site helps out alot. Good luck
cbr600f2
Member - Posts: 7
Posted: November 17, 2007 at 11:19 AM / IP Logged
thank you but i do not have a tech sheet to get wire color information unfortunately.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
