94 acura integra brake switch??
liemz
Posted: February 22, 2003 at 2:27 PM / IP Logged
i have a 94 acura integra .  i need to find brake switch..and also need help to hook up a 12v relay to my door triggers unlock n lock..how do i find n do that???my brain is hooked up ,but my lock n unlock dont work. i have a black widow 7150 and need help on the red wire on the door triggers. i also need help looking for the parking light wires in my 94 integra..thank you
liem
Bnluis
Silver - Posts: 578
Posted: February 22, 2003 at 2:41 PM / IP Logged
94 acura integra
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ white         |-  |drivers kick panel *2       |
|     POWER UNLOCK|BLACK/ red           |-  |drivers kick panel *2       |
| PARKING LIGHTS +|RED / black *3        |   |grn plug above fusebox      |
| PARKING LIGHTS -|blue/red            |   |factory alarm (if equipped) |
|       HEADLIGHTS|RED / wht (low)  12awg|+  |steering column             |
|     DOOR TRIGGER|lt. GREEN/ red *4    |-  |drivers kick panel *2       |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|green               |-  |*6                          |
|         HOOD PIN|yellow/red          |-  |drivers kick panel          |
|  FCTRY ALARM ARM|factory remote only |   |                            |
|FCTRY ALRM DISARM|factory remote only |   |                            |
|       TACHOMETER|blue                |   |distributor *1              |
|      SPEED SENSE|orange              |   |instrument cluster          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|gray or blu/grn     |-  |steering column             |
|           WIPERS|blue & blu/yel *5   |-  |steering column             |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/yel - blu/grn   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|green - grn/yel     |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|yel/grn - yellow    |A  |in drivers door or dkp      |
| SUN RF OPN/CLOSE|grn/red - grn/yel   |A  |sun roof switch             |
|        RADIO 12V|WHITE/ blue          |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|    POWER ANTENNA|YELLOW /GREEN        |+  |radio                       |
|       LF SPEAKER|blu/grn - gry/blk   |   |radio                       |
|       RF SPEAKER|RED / grn - brn/blk   |   |radio                       |
|       LR SPEAKER|blu/yel - gry/wht   |   |radio                       |
|       RR SPEAKER|RED / yel - brn/wht   |   |radio                       |
Notes:
*1 Also found in a 16 pin white or gray plug to the left of the fusebox.  *2 In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.  *3 Also a male blade terminal is available in fuse box.  *4 Looks like 14 awg wire but mostly insulation.    *5 Use both and diode isolate each.  *6 12 pin blue plug on top center of fusebox.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Moderator - Posts: 12,488
Posted: February 22, 2003 at 5:27 PM / IP Logged
Why do you need to use a relay for the door locks and the door triggers? The door tigger is a (-) activation and so are the door lock/unlock wires.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
