need 06 kia sportage vehicle wiring
visionsss
Member - Posts: 19
Posted: November 25, 2007 at 7:40 PM / IP Logged
Doing an alarm possible remote start and need the vehicle wiring for an 06 Kia Sportage 4cyl.
Fred Kincaid
Visions Sound & Security
GPS Northwest
techman93
Silver - Posts: 591
Posted: November 26, 2007 at 11:44 PM / IP Logged
Battery          RED          (+)          PIN 2 IGNITION HARNESS
Ignition 1     BLUE          (+)          PIN 6 IGNITION HARNESS
Accessory 1     ORANGE          (+)          PIN 3 IGNITION SWITCH
Accessory 2     PINK          (+)          PIN 4 IGNITION SWITCH
Starter 1     GREEN          (+)          PIN 1 IGNITION HARNESS
Tachometer     BLUE          (AC)          PIN 19 BEHIND CLUSTER (LARGER OF 3 PLUGS) PIN 17 AT ECM
Parking Lights     GREEN          (+)          PIN 11 OR 17 IN AN 18 PIN CONNECTOR BEHIND FUSE BOX OR RED / BLACK IN HARNESS HIGH IN DRIVERS SIDE DASH
Brake Lights     BLUE          (+)          AT SWITCH ABOVE PEDAL
Horn          BLUE          (-)          AT COLUMN
All Door Trigger ORANGE     (-)          CONNECTOR C (22 PIN) AT ETACS MODULE. THIS WIRE CONTROLS THE DOOR AJAR WIRE IN THE CLUSTER, DO NOT USE FOR DOME ILL.
Domelight Super     BROWN          (-)          AT VEHICLE FUSEBOX BEHIND DRIVERS SIDE OF DASH WHITE PLUG
Trunk Trigger     BLUE (TAIL GATE)(-)          22 PIN CONNECTOR AT ETACS MODULE PIN 14 OR IN PLUG ON BACK OF CLUSTER PIN # 2
Alarm Disarm     BROWN          (-)          IN HARNESS IN DR. KICK
Alarm Arm     YELLOW          (-)          IN HARNESS IN DR. KICK
Power Unlock     DARK BLUE     (-)          DRIVERS KICK PANEL     Power Lock     GREEN          (-)          DRIVERS KICK PANEL
2.0 engine
Module 1     ETACS IS BEHIND RADIO.
Module 2     ICM (DOOR LOCK RELAY MODULE) HIGH IN DRIVERS KICK
Module 3     ECM (ABOVE DIONOSTIC CONNECTOR)
2.7 engine
Module 1     ETACS IS UNDER CENTER CONSOLE CLOSE TO FIREWALL
Module 2     ICM RELAY BOX (HIGH IN DRIVERS KICK)
Module 3     ECM (ABOVE BRACKET FOR DIOGNOSTIC CONNECTOR)
Audiovox technical data
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
