disconnecting the battery on a vehicle
rosedalechip
Posted: November 27, 2007 at 10:53 PM / IP Logged
I have heard that on some cars removing either the negative or positive post on a car battery first would keep the vehicles computer settings from getting screwed up. Is there a right way or a  wrong way to remove a battery? Is this true on certain cars? Can anyone verify this?  Excuse me if  the questions seem silly !   I just don't like not knowing.
I hear voices in my head !
haemphyst
Platinum - Posts: 5,059
Posted: November 28, 2007 at 12:32 AM / IP Logged
My understanding is that neither will or should matter. Once you disconnect the power from EITHER terminal, the car is electrically dead.
I can't see how disconnecting one or the other first could make any kind of a difference.
rosedalechip
Posted: November 28, 2007 at 11:39 AM / IP Logged
Thanks I appreciate it.
donpisto
Member - Posts: 49
Posted: November 28, 2007 at 12:29 PM / IP Logged
Disconnect: negative then positive
Reconnect: positive then negative
If you were to disconnect the positive first, your vehicle is still grounded, that's a no-no. Also, if you're wanting to hook up an amplifier and whatnot, just disconnect the negative and that's it.
audioman2007
Copper - Posts: 580
Posted: November 28, 2007 at 2:42 PM / IP Logged
i have a 02 cavalier and I am able to disconnect both battery terminals without losing my computer info. I just need to reconnect in a certain amount of time
haemphyst
Posted: December 11, 2007 at 1:34 PM / IP Logged
There is a perfectly valid reason for that. If you disconnect the positive first, the car is still grounded to the battery, and the possibility of landing a tool across the positive terminal and the chassis is very real. In a positive ground car, such as older VW bugs, you disconnect the positive terminal first, for the same reason.
There is no other reason than what I have stated above to remove the negative battery cable first. It's for safety only.
advanced_audio
Copper - Posts: 170
Posted: December 11, 2007 at 1:39 PM / IP Logged
Also would like to add, make sure you have the code for the radio if it has the theftlock crap on it, before you disconnect the car from the battery.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
