jeep compass audio wiring
ray9043
Posted: November 30, 2007 at 10:09 PM / IP Logged
hi ¡¡ i'm new in this forum, and a have a problem with my jeep compass 2007, i have the jeep compass with premium boston audio, it sound's good but i need more bass.  the vehicule comes with 2 amplifiers (fabric installation) ,one 8 chanel amp for midbass and tweter, and one for the bass.  and i need to get the signal of one amp to feed my pioneer gm520t., but,  i don't know what wire use for signal¿¿  and i don't know what wire use like remote to turn-on my amp¿¿ somebody have the wire color code for my jeep ¿¿¿
thanks¡¡
techman93
Silver - Posts: 591
Posted: December 01, 2007 at 7:06 AM / IP Logged
Battery             RED / LIGHT BLUE        (+)     RADIO HARNESS
Accessory       WHITE/ ORANGE        (DATA) RADIO HARNESS
THIS VEHICLE USES THE CAN DATA SYSTEM FOR ACCESSORY TURN ON, USE AN ADAPTER OR RUN A WIRE TO THE FUSEBOX
Ground             BLACK / YELLOW         (-)        RADIO HARNESS
Power Antenna     GRAY/RED         (+)        RADIO HARNESS
THESE WIRES SUPPLY THE AUDIO SIGNAL TO THE AMPLIFIER
LF Speaker (+)             GRAY/VIOLET
LF Speaker (-)          GRAY / YELLOW
RF Speaker (+)          DARK GREEN/ VIOLET
RF Speaker (-)          DARK GREEN/ YELLOW
LR Speaker (+)          DARK GREEN/ DARK BLUE
LR Speaker (-)          DARK GREEN/ BROWN
RR Speaker (+)          GRAY/DARK BLUE
RR Speaker (-)          GRAY/ORANGE
Amp Location          BEHIND RIGHT SIDE TRIM PANEL IN CARGO AREA
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
ray9043
Posted: December 01, 2007 at 10:09 AM / IP Logged
hi ¡¡ thanks for the quickly answer ¡  this morning i was looking the wiring into my car and ohh surprise¡ i found a second amp ¡¡ this second amp is for the bass and i found this amp behind a panel, and now a i have a new problem , i need to know the wiring of this amp, because i'm going to install woffers and i need the signal of the bass not of the other amp.  and other question ¿? can i use the power antena wire  like remote? to turn-on my amp? thank you ¡¡
