07 titan xe cc unlock double pulse
richie_lambe
Posted: December 02, 2007 at 9:21 PM / IP Logged
I'm installing my first remote keyless entry/alarm.  It's in my 07 Titan XE CC.  It already has power door locks.  I've completed the install and everything works except the unlock.  I''ve been reading that the unlock needs a double pulse.  I bought an alarm/entry system off Ebay.  From what I can tell, it doesn't provide a double pulse on the unlock.  Is there some way around this, or can I purchase something (hopefully inexpensive) to provide the double pulse?
Any and all help would be greatly appreciated!
KarTuneMan
Platinum - Posts: 7,056
Posted: December 02, 2007 at 9:48 PM / IP Logged
I would PM hotwaterwizard, and ask for his help.
techman93
Silver - Posts: 591
Posted: December 02, 2007 at 11:12 PM / IP Logged
links to a couple options for your problem.
https://www.the12volt.com/installbay/forum_posts.asp?tid=92024&KW=double+pulse
https://www.the12volt.com/installbay/forum_posts.asp?tid=40281&KW=double+pulse
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
richie_lambe
Posted: December 03, 2007 at 10:53 AM / IP Logged
You guys are great!  I'll go with one of these options and let you know how it turns out.  I truly do appreciate the help!
richie_lambe
Posted: December 15, 2007 at 3:36 PM / IP Logged
I bought and installed the DEI 452T, but no luck.  No signal made it to the wires I was tapping into.  Traced the problem to a lifted trace on the back of the PCB in the alarm.  After fixing that, the 452T worked like a champ!  I'm now enjoying the convenience of keyless entry, plus the added security of the alarm.
Thanks again guys for all your help!  I've learned a lot during this installation, plus have thoroughly enjoyed checking out all the info on this site.
