looking for becu on a 2008 camry
roadworks
Member - Posts: 31
Posted: December 03, 2007 at 9:31 PM / IP Logged
I'm in the middle of doing a 2008 Toyota Camry.. and I have to go to the BECU to connect the negative lights. The Audiovox site is the only place that had any info on this car. It says the BECU is located in Vehilce fuse box...now I found fuse under the dash.. and there is a fuse panel under the hood..  there is some sort of module beside the fuse panel under the hood..Is this the BECU?.. Any help would be appreciated...Thanks
rabenoja
Copper - Posts: 61
Posted: December 03, 2007 at 10:13 PM / IP Logged
No need to go to the BECU for the negative lights.  You can grab them at the headlight switch.  The wire is black and it's negative.
roadworks
Member - Posts: 31
Posted: December 03, 2007 at 10:46 PM / IP Logged
Thanks .. I will test it in the morning..
