remote start, 2003 sequoia
goser
Member - Posts: 14
Posted: December 05, 2007 at 5:12 PM / IP Logged
I'm looking for a remote start for a 2003 Toyota Sequoia.  I can't seem to find a model number for an appropriate bypass module that doesn't require a key to run.  Could someone provide me with a model number for one?  Also, what would be a recommendation for a cheap remote start system?
chadwa2003
Copper - Posts: 353
Posted: December 05, 2007 at 5:23 PM / IP Logged
i'm pretty sure you can use a pkt from bypasskit.com
peterubers
Silver - Posts: 706
Posted: December 05, 2007 at 5:41 PM / IP Logged
ultrastart 1270 --> about $40-60
PM me if you're interested, I have a unit sitting on my shelf that I have not used (no trunk output) but brand new, range is about 1/4 mile without any interference.  you can go to ultrastarters.com and read about it.
The search function is your friend.
goser
Member - Posts: 14
Posted: December 07, 2007 at 5:50 PM / IP Logged
I went with a crimestopper rs1505dp and an IX-05 bypass off fleabay.  Thanks for the replys
goser
Member - Posts: 14
Posted: December 07, 2007 at 5:51 PM / IP Logged
I'm looking for some wiring info for a 2003 Sequoia.  I have the remote start basics, but there's a couple details I can't seem to pin down:
I'd like to control the rear window, down at least, preferably both.  I thought originally to tie into the switch on the dash with a relay, but it doesn't seem to have power when the vehicle is off.  Is there somewhere else to tie in near the front of the vehicle?  If not, does anyone know the wires and triggers I'd need to tie into in the back tailgate?
I noticed for the 2002 model you can tie into the tach and hood switch inside the cab.  Are there similar wires in the 2003 so I don't have to go through the firewall?
Also on the 2002 there's a blue/white wire below the radio to control the rear defrost.  Is there a similar wire to control the rear (and front) defrosts on the 2003?  When I did my last install I was able to open the A/C unit and wire a relay across the switch to 'press' it for me, is it possible to do the same here?
Finally, if someone could post pictures or instructions on how to remove the dash, door panels, and tailgate panel I'd appreciate it.  I'll need to open the tailgate panel to fix the broken door handle anyway...
