1999 Camry Door Locks
slarsen
Posted: February 23, 2003 at 11:06 PM / IP Logged
I just fininshed installing an aftermarket remote keyless entery system on my 1999 Camry CE.  Everything was working fine until I accidentally switched two leads as I was cleaning up.  Now the power locks don't work at all on any door or with the remote.  Does anyone know if there is a fuse somewhere for the power locks, or have I just fried the entire system.  Any suggestions would be appreciated.
Thanks,
Sean1999 Camry Door Locks -- posted image.
slarsen
Posted: April 13, 2003 at 11:30 PM / IP Logged
I figured out what the problem was with my locks, so I thought I would answer my own reply in case someone else had a similar problem.  There was an integrated circuit board that was burned out.  The circuit board is located behind the fusebox on the driver's side and was labelled relay integration.  This circuit board contains the relays for the door locks.  Luckily I was able to find a used one at an auto wreckers as Toyota wanted $450 CDN to replace it.
Sean
