2007 subaru forester xt wiring
jfran00
Posted: December 13, 2007 at 10:00 AM / IP Logged
Hi. I'm looking to install a Viper 5900 alarm/remote start in my Sports XT and was looking for a wiring diagram.
Thanks.
mikvot
Gold - Posts: 1,043
Posted: December 16, 2007 at 3:11 PM / IP Logged
2007 subaru forester xt wiring -- posted image. Remote start / security / GPS
 Wire/Function Colour Location/Description Polarity
 12 VOLTS White Ignition switch harness   +
 IGNITION Green Ignition switch harness   +
 ACCESSORY Yellow Ignition switch harness   +
 STARTER WHITE/ black Ignition switch harness   +
 KEY SENSE WHITE/ green Ignition switch harness   +
 TACH SIGNAL ORANGE / white At ECM behind glovebox   AC
 LOCK GREEN/ red At module on left of steering column   -
 UNLOCK Lt.GREEN/ YELLOW At module on left of steering column   -
 DOORPIN Pink/black At module on left of steering column   -
 BRAKESWITCH WHITE/ black At switch above brake pedal   +
 PARKLIGHTS BLACK/ white At light switch harness   -
 You must test for this wire with the ignition turned on.
 HORN RED / green At steering column   -
 VSS WIRE GREEN/ black At ECM behicle glovebox
jfran00
Posted: December 16, 2007 at 3:21 PM / IP Logged
Thanks so much.
