Posted: December 06, 2014 at 1:02 PM / IP Logged
Posted: December 06, 2014 at 1:31 PM / IP Logged
Posted: December 06, 2014 at 2:16 PM / IP Logged
Posted: December 06, 2014 at 2:17 PM / IP Logged
Posted: December 06, 2014 at 2:44 PM / IP Logged
Posted: December 06, 2014 at 6:23 PM / IP Logged
Posted: December 07, 2014 at 9:41 AM / IP Logged
Posted: December 07, 2014 at 10:56 AM / IP Logged
Posted: December 07, 2014 at 12:07 PM / IP Logged
Posted: December 07, 2014 at 5:30 PM / IP Logged
Thursday, April 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Does it need actual wires run aka hardwire for it to work?
1) Does it need a wire run from e-brake?
2) Also assume door trigger, since instruction says that if any door is opened, it is cancelled. Figured it picks this via data, but we did tap for lock/unlock.
3) Where is the clutch wire run to? It seems like it does nothing when connected to the clutch pedal harness?
Is anything else required like a module?
Could someone please help with this. I would greatly appreciate it.
