6v to 12v
oxshortyxo
Posted: August 11, 2010 at 10:23 PM / IP Logged
how do i turn 6v into 12v i have a component that takes 12v but i only have six volts coming from the switch any answers ppl i tried relaying it but the relay doesn't activated off of 6v
Leo hedge
KPierson
Platinum - Posts: 3,527
Posted: August 11, 2010 at 10:43 PM / IP Logged
A 2n3904 transistor would work great - run the voltage in to the base, ground the emitter, and hook the collector to the (-) side of a 12vdc relay. You will need a diode across the coil of the relay.
Kevin Pierson
Sunday, October 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
