08 jeep liberty remote start
joshk707
Member - Posts: 11
Posted: December 28, 2012 at 2:39 PM / IP Logged
Hey guys I have started my first remote start install and very quickly decided it was the wrong choice to DIY. I have a viper 5704 with the xpresskit dball bypass, I am installing this on a 2008 Jeep Liberty and i have gotten everything to work except the remote start. when i try to remote start the car the remote says REMOTE START ERROR and the brain clicks 7 times. I see on my install tech sheet that the miltiplex wire needs a 610 ohm resistor do i still need to do that being i have the DBALL? any help would be greatly appreciated and thanks in advance.
joshk707
Member - Posts: 11
Posted: December 28, 2012 at 4:04 PM / IP Logged
i just got closer by connecting the neutral safety wire to ground. that allowed the remote start to turn the ignition to on but car doesn't crank, it tries that 4 times then beeps on the remote remote start error but no flashes on the headlights to signal what the problem is.
smokeman1
Platinum - Posts: 1,589
Posted: December 28, 2012 at 4:08 PM / IP Logged
Wire 2 Wire or D2D?  With or without harness?  Keyless or NO keyless?  Did the DB-All program correctly?
If Wire 2 Wire, (W2W)  can yo list your connections?
joshk707
Member - Posts: 11
Posted: December 28, 2012 at 5:50 PM / IP Logged
D2D, without harness, Keyless, the DBALL did program correctly, ive connected everything just like on the dball install sheet program 401.CHRYSLER - Install type 3B.
I have also connected the neutral safety wire to the ground wire on the remote start.
smokeman1
Posted: December 28, 2012 at 7:02 PM / IP Logged
Is the viper set to manual or automatic transmission?  Does the car still start with the key?  If so, try inserting the key in the ignition, do not turn it, the try remote starting. See if it starts.
joshk707
Member - Posts: 11
Posted: December 28, 2012 at 7:25 PM / IP Logged
it was set to manual but i changed it to Automatic, the car does start with the key but not with it just sitting in the ignition.
smokeman1
Posted: December 28, 2012 at 8:16 PM / IP Logged
Does it remote start now that it is in automatic?  Or what does happen.
Have you done the TACH learning?
joshk707
Member - Posts: 11
Posted: December 28, 2012 at 8:35 PM / IP Logged
it turns the instrument cluster panel and radio like if you were to turn the key to the on position and then turns off abruptly then tries again 3 more times then sends the REMOTE START ERROR code to the 2 way remote.
I have not tried tach learning because the car has to actually try to start before you can learn the tach, right?
joshk707
Member - Posts: 11
Posted: December 28, 2012 at 8:41 PM / IP Logged
to learn the tach i need to connect a tach wire correct?
I assumed since the dball instructions did not tell me to connect a tach wire i did not and assumed the dball would get the info it needed from the canbus.
do you think connecting a tach wire and learning the tach would fix the issue or because the engine isnt even cranking there is something else wrong?
smokeman1
Posted: December 28, 2012 at 9:08 PM / IP Logged
I have used two DB-All for the first time last month. One on a 2005 Equinox and the other on a 2012 Edge. I did not use D2D on either of those installs because of all of the negitive posting about D2D.  I used W2W on both and they learned the TACH through the DB-All. That being said, to me it seems like the bypass might not be programed/working. Or time to double check the connections.  Could try reprogramming thr DB-All.
Is the DB-All flashed with the correct firmware?
Ignition out of RS to ignition at ignition switch, Pin 3......Pin 8 & 9 from 12 pin of DB-All to MUX, Pin 1..... CAN low, Pin 7 to Pin 4 Tan of 14 Pin on DB-All
Can high Pin 6 to Pin 3 Tan/Black of 14 Pin of DB-All....and  D2D connector.
