Posted: September 23, 2014 at 12:23 PM / IP Logged
Posted: September 23, 2014 at 4:42 PM / IP Logged
Posted: September 24, 2014 at 11:11 AM / IP Logged
Posted: September 24, 2014 at 12:13 PM / IP Logged
Posted: September 24, 2014 at 1:02 PM / IP Logged
Posted: September 24, 2014 at 8:47 PM / IP Logged
Posted: September 24, 2014 at 9:43 PM / IP Logged
Posted: September 24, 2014 at 10:14 PM / IP Logged
Posted: September 24, 2014 at 11:13 PM / IP Logged
Posted: September 26, 2014 at 9:36 PM / IP Logged
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
or
Rechecked - YES it is; I can tell from its disconnect RR stop and reconnect to (RR) flasher switching.
But that is NOT the same as the 5700R turn signal switch which (afaik...) is merely a combined turn & hazard signal switch.
And that reminds me of what I started writing in my last reply, namely:
I looked for a "simple"
circuit diagram of how they connect, but no...
[ In 2007 I wrote a superb document explaining what was required (universally) with specifics down to wiring level for my vehicles. I stopped when I realised I had confused/swapped my logic - ie, interchanged flasher side with brake/reverse side - what I call a "simple but tricky" experience. Some find&replace editing would have corrected the text etc, but coinciding with "club politics" I determined I was only doing this the benefit of others (and since they preferred reinventing wheels...) ]
I won't continue down the combined path unless required - I simply alerted Jim (OP akuhead) to that issue - but of course if Jim needs further info...
And of course I wouldn't expect you Custom_Jim to put me thru the agonising torture of having to revisit the subject and - worse still - having to think or continue old documentation or pics?!!
